Question for you
bilM
Bill
Aberdeenshire
Porsche Cayenne Audi TT Triumph R3 Hymer MLI580
How can I tell if my CT came with Rear-Axle Steering thanks
Fsudoles
Tom
Lauderdale by the Sea, Florida
2022 Porsche Taycan RWD
I don’t have it, but if you are pulling in or out of a parking spot, if you cut the steering wheel hard left let’s say, the left rear tire should be turning inward (the opposite direction) so a quick look after you put the car in park should let you know. I‘ll let the experts jump in though.
Explorer
Sweden
Taycan CT4S, 992C4S, MB GLE 350 de
On my 992 with RAS, the backup lines are yellow as opposed to my Taycan w/o RAS which are blue.
Could that be a general difference between RAS and no RAS for P-cars?
bilM
bilM
Bill
Aberdeenshire
Tryed that Fsudoles back wheels do not turn at all.
your porsche connect account can provide you with your vehicle's original build sheet as a pdf download - it will list all factory installed options.
simcity
Sean
Suffolk, UK
'23 Taycan Turbo
Yep as said, go to the My Porsche web portal:
https://my.porsche.com/core/gb/en_GB/
Login with your ID and click on your vehicle in the overview, scroll down and go to Techical Data section. Click on ‘Vehicle Specifications & Technical Data’ - a pop up will shown you the full factory build spec.
RAS is listed under ‘Transmission / Chassis’
dtich
Southern CA, USA
'23 Taycan GTS;'12 Model S(sold); Aprilia; Triumph
I'll highjack this thread a tiny bit with a question of my own as this last thing is somewhat related - i have tried to download my monroney label a couple times and i get nothing. no link. no attempt. and no file.
is this a function that will only be enabled after car's arrival at the dealer (it's still on boat)? or is there actually something going on wrong with my portal?
thanks!
Porsche Taycan Question for you 1684769377473
CAGCTG
Stephen
Solana Beach
2016 GTS, 1997 Carrera, 2023 Taycan GTS
I ordered rear wheel steering on my 2023 GTS. It is awesome. Low speed maneuverability is tremendous. Highly recommend to anyone ordering a new Taycan (or other P-car for that matter).
G7SUM
Gary
Glasgow
GTS ST 2023
I second that. Its a must on a car this size!
WasserGKuehlt
WA
4CT, 996C2, MacanS
The Porsche Active Rear Steering and Handling (PARSH) is the one option I sometimes regret not including. It was a conscious decision (I dislike 'active' anything), and I don't know that it would have been much better in tight spaces, but I had not accounted for the stress of trying to maneuver in said spaces. It is a big car, and its shape (upper cabin/corners being inboard vs its footprint) makes backing maneuvers a bit difficult.
