Questions About Taycan Range and Charging
pdavison
Paul
RR Velar, Harley Davidson Sportster
I'm showing 170 miles at 80% currently, I do relatively short journeys and use heated seats etc so perfectly normal.
peterjames
peterjames
Kidwelly
Thanks, everyone. The car now displays 205 miles at 85% battery. I've adjusted my driving style slightly, opting to use regenerative braking on auto mode most of the time.
or1
O
Norway
Taycan GTS ST
You may want to reconsider that regeneration setting, depending on what you are after. A Taycan regenerates as much as it can in any setting (except when new, for the first few miles each day, or at very low speed). Avoiding any retardation is more efficient than mixing regen and acceleration, because there is some energy loss (20-30%) in the regen cycle.
So the coasting setting will give even more range than regen++ if you actually coast more then.
But what you feel to be more convenient may cause you to use other settings.
peterjames
peterjames
Kidwelly
I was a bit confused about regen, but from what I gather, it's okay to keep it on auto mode for situations like going down hills or in stop-start traffic. Perhaps it's just not recommended for motorway driving.
Auto recuperation is a bit pointless on hills or motorways - you need to be close to the vehicle in front to derive any braking and motorways are typically at a constant speed. Manual would be much better - particularly on a downhill if you didn't want to coast and would logically gain more miles travelled than added by putting energy put back into the battery via recuperation. Stop start - again marginal as you aren't travelling fast enough to require enough deceleration to add much energy back into the battery.
