Range at high speeds?
offplan
UAE
Taycan 4S , bicycle , my own feet
I find it very hard to buy the 300 mile range @70 mph. on a recent trip, running between 70 and 77 MPH, I barely eked out 200+ miles consumption was between 3.1 and 3.4 mile per kwh.
at 125 mph you will consume far more and go far less.
when road tripping there is a balance you need to have between speed and range.
I daily drive (4S PB+ 20") around 150 km with the trip computer showing an avg. speed of 95kmph (normal mode with AC on normal at 22C, in ambient temps of 37C-44C), i can confidently say that the car can get 290miles (465km) at 100% SoC
Can you share your consumption data - miles / kWh - available from 'Total Trip'?
WuffvonTrips
Paul
Up North
Taycan Turbo CT
Drag force in kWh/100mi for a given mph:
mph^2 * 0.00273
And the metric folk: kWh/100km for a given kph:
kph^2 * 0.00066
Mixing metric and imperial units in calculations invites error, so being a not very trusting soul I felt compelled to do my own calculations from scratch...and must now applaud your accuracy.
Abdul
Glasgow
Gentian Blue Taycan 4S...previously Ice Grey RWD
tldr; 146 miles
I didn't double check any of this so there's a non-zero chance of errors, which I will correct if pointed out or if I find myself.
Some basics
If energy is 83.7 kWh (user-accessible battery capacity) and distance is equal to 300 miles, we can say that the car used 0.279 kWh per mile or 27.9 kWh per 100 miles.
Because work (energy use) is equal to force times distance, energy per distance is a unit of force. i.e. the 27.9 kWh/100mi tells us something about the force required to move the car (although not entirely because not all of the energy was used for force).
Note that one kWh/100mi is equal to about 223694 N, but I actually like kWh/100mi better for this exercise, so we'll keep it. And this is 17.3 kWh/100km going 482.8 km at 112.6 kph for the metric people playing along at home.
Drag is a drag...
The dominant change in force for a change in speed will be drag. The drag force is equal to the coefficient of friction times the area times the fluid density times the speed squared.
Porsche has published the drag coefficient as 0.22 Cd and the frontal area as 2.33 m^2.
Air density is 1.2 kg/m^3.
Other standard units are meters per second and, with an additional scalar of 0.5, the equation yields newtons. But we don't want N or m/s. We want kWh/100mi and mph.
So, we'll plug in the numbers for air and the Taycan, add some other scalars to convert units to our (my) preference, and we have the below:
mph^2 * 0.00273
kph^2 * 0.00066
Okay, so now we can say, at 70mph, the drag force is 70*70*0.00273 or about 13.3kWh/100mi. (8.3kwh/100km).
So, of the 27.9kWh/100mi consumption rate, 13.3kWh/100mi is from drag.
This leaves 14.6kWh/100mi that we won't change as speed changes*.
(9.1 kW/100km)
Now, finally, for the OP's question, how does the range change at 125mph?
125*125*0.00273 = 42.7 kWH/100mi ? (26.7 kWh/100km)
This is the new drag force to replace the 13.3kWh/100mi at 70mph.
Add the 14.6 kWh/100mi and we're at 57.3 kWh/100mi. (35.8 kWh/100km)
Going back to battery energy of 83.7 kWh divided by 57.3, and times 100, we get....
146 miles (234 km)
*This 14.6kWh/100mi does likely change some with speed. For example, there are some time dependent energy uses such as AC that improve this number at higher speed. Rolling resistance may change some as tire temperature changes from the different speed. But as others have pointed out, the drag is by far the largest factor...and also most straightforward to just calculate.
Wow...incredible work. I feel stupid as I just want to drive ?
Valen
Paris, France
Taycan 4S, Eva Ribelle RS
Just made a 1000 km highway only trip (roughly 620 miles), at 150 km/h (90 miles) most of the time and could do 350km (220 miles) between each stop.
4S PB+ ok weather, no rain, little wind
BigBob
Hmm. I just did 2 journeys of around 200 miles. Average 65mph and 55mph. Temperature around 12-15c. Mostly motorway.
Both journeys the average I got was 2.4 miles/kw. Basically 200 miles range. Not desperately impressed and pretty certain it's been worse since the big software update.
Bill33525
Bill
Tampa Fl
tldr; 146 miles
Some basics
Drag is a drag...
mph^2 * 0.00273
kph^2 * 0.00066
(9.1 kW/100km)
146 miles (234 km)
Jason Fenske, Engineering Explained would give you an "A" for the homework assignment! I felt like I was listening to Jason as I read your post. Nice job!
Bill33525
Bill
Tampa Fl
I go 90 SF to LA and you’re already at 200 mi range. Averaging 70 ive never gotten more than 220. Don’t know how anyone got 309
Wheels and tires can make a big difference. The 70MPH range tests with the big range were done on aero wheels and skinny tires.
Doc Sportello
CT4
Interesting. So can we agree on an "ideal" speed for motorway trips, balancing speed and efficiency? Please say it isn't 70mph...
(Not that I'll adhere to it - there's something glorious about planting your foot at 70mph and waiting for the push from second gear engaging, and watching traffic disappear)
kort
'23 Lucid Air GT
sorry to say this but if you are on a road trip and need to maximize your range I've found the sweet spot to be 70-75 MPH. when I know that I am not stretching the range limits I will mash the pedal more.
Chris8536
Chris
San Francisco
Taycan 4S (Sold) X7 M50i (sold) cayenne GTS coupe
Had both then. Turbo Aeros on sport efficient tires.
TDinDC
Washington, DC, USA
Such an interesting topic.
Air resistance is, I think, the most important variable when thinking about maximizing range in the real world.
The size of the air resistance (Ra) can be determined by using the following formula (assuming you are in clean, stable air and not drafting behind a car or truck, and it is not windy, raining, snowing or foggy):
Ra= 1/2 * ρ * v squared * Cx * S
where ρ is the instant specific weight of the air [kg/m3], v is the speed of the vehicle (driving speed; velocity) [m/s], Cx is the air resistance coefficient (drag coefficient or coefficient of influence of the body shape on air resistance) [-], S is the size of the front area of the vehicle [m2].
The v squared is why vehicle speed is obviously so important for range.
The shape of the resulting air resistance plots should be identical no matter which vehicle you are discussing (albeit the values would be different), which would lead me to think that the power consumption plots should similarly be identical, but they are not. I'm not sure why some vehicles have a different slope in their plotted power consumption values at the higher speeds.
I feel like the Taycan does not take nearly as much of a range hit when I exceed 70 mph as my Tesla Model X did, which doesn't entirely make sense to me either given the formula above, which suggests that the impact of speed should be similar (I unfortunately do not have any data from the Taycan like I have for other EVs).
Now, it's possible that the range calculator impacts my perception, because the Tesla was always over optimistic at the beginning of the trip and it nearly never fully delivered, while the Taycan seems to be pessimistic at the beginning of the trip but ends up over delivering.
JimBob
Toronto Canada
The difference in the power consumption you are seeing may result from where you are measuring the power. For the system as whole P = F * v where P is the power in watts, F is the total drag force and v is the velocity. For similar cars, this should be similar. But if your power is measured as the draw from the battery for a given speed, P = V * A, then different motors and drive trains will use different amounts of power to achieve the same speed even if the cars have similar aero.
