mystermykee
- Mar 30, 2022
- Bay Area
- 9j1, 9y0 hybrid, 992.1
Thanks! Those are helpful.Ok, so it seems the corner lights are behaving as if they were a US version, only the very bottom bar is amber instead of red (but still acting as both brake and turn signal). Surprisingly the middle bar is not behaving the same. I would have expected the amber part to light up together with the brake/turn signal.
From post #7, it's supposed to work like this for turn signals outside of NA:
Also from 2020 Taycan technical manual:
I agree. One would assume if the ambers for outer housings are acting like NA spec outer housings, the center direction lights should as well, light up during braking. I'm thinking perhaps the center logic is a bit different. As you mentioned before, the center could be faulty but I hope, hope.....the likelihood of that is low since there are no faults and it's basically brand new from Suncoast.
I have an appointment with another dealer in my area next week to get the heater recall done. I will ask them to take a look. I'm hoping it'll be easy as contacting Porsche to advise on the issue, and then sending instructions to the dealer to get it coded correctly.
