Rearrange media source buttons on PCM?
MLD
Marc
SC, USA
I know you can rearrange the main icons on the PCM home screen but I can't find a way to change the order of the media source buttons (radio, online radio, SiriusXM, Apple Music, Apple Podcast, Bluetooth). Since I never use terrestrial radio and almost never only radio and the SXM trial didn't work, it means the first 3 media source buttons are all but useless to me and I need to use the "..." menu under Media | List to get to what I do use. Is there a way to change which sources show up versus which require the "..." to access?
andrewket
Andrew
Vienna, VA
Yes, there is. I did this a few days ago. I’ll have to go look.. but perhaps settings / comfort systems?
I have Apple Music first now and then USB.
MLD
Marc
SC, USA
Thanks. That's all I needed to know - that it's possible. So, I just went through everything again and found the answer.
Go to Media, press the "..." menu in the bottom right (in NA, likely bottom left in UK). Scroll down to the bottom and you'll see "Adjust sorting of sources". From there, it's the normal hold and drag to sort as desired.
Thanks again.
NC_Taycan
Lewis
Wake Forest, NC
So many things hidden in the ... menus...
