Sirius XM 360 not working?
superflytnt
Seth
Vienna, Virginia
2021 Taycan 4S
Had this same problem last week, three days into ownership. Dealer sent me a workaround that uses the joker buttons to access SAT radio. Says that is a permanent fix that links the radio to the PCM display. Attaching a screenshot here.
This worked almost perfectly. Once I was able to change the source to XM with this trick I had to click onto a different screen to trigger a terms of service "accept" button. Once I did that, XM worked perfectly. Thank you!
DerekS
Derek
Los Gatos, CA
2025 Taycan GTS
If someone is maintaining a FAQ this should be in it - great tip and it worked 100%.
DaveCinNJ
Dave
New Jersey
2021 Taycan 4S
I picked up my 4S on Saturday, and XM worked fine until this morning. I searched the Forum and found this thread, and it worked in 30 seconds. This truly saved me hours on the phone or a trip to the dealer. Thanks to everyone!
Dslev
2021 Taycan Turbo
Picked up my 2021 Taycan Turbo on Friday, Sirius stopped working this AM, the Joker Key fix worked perfectly. Thanks all for the thread.
XLR82XS
LXA
SW FL | Vegas
This worked for me. I hope it “sticks”.
Thanks.
Joker key thing did not work for me. Took the car to dealer last Saturday and they knew about the Joker key source thing as well and it didn't work. XM is greyed out - it worked for 2-3 days after delivery then quit. Their diagnostic info is being sent to Porsche for evaluation and I'm awaiting a response. I'll update here once it get figured out. (2021 RWD | 4/21 build)
XLR82XS
LXA
SW FL | Vegas
Porsche called today and stated a software patch/update resolved the issue and it is now operational.
DerekS
Derek
Los Gatos, CA
2025 Taycan GTS
I have to use the joker key workaround literally every single day now.
Just me?
Every time I do it, I get the free trial popup.
YugoNation
Chicago
Audi a3 etron, BMW x3
I am having this issue now in my 2021 4s that just got delivered. Software on this car is pretty janky.
XLR82XS
LXA
SW FL | Vegas
Just me?
Got my car back. Software update is the solution according to Porsche. Mine's working all the time now.
Jase700
Mclean, VA
2021 Taycan Cross Turismo
Has anyone figured out a way to make SiriusXM automatically start when you turn the car on? Anytime CarPlay is connected, it basically makes me click through menus to start the satellite radio.
Also, has anyone found a way to be able to monitor the satellite stations while Carplay is active? in my Panamera, Carplay didn't take up the whole screen and I could have 1/3 of the screen still show the Sirius track and change the station.
lazvek
lazvek
Laz
Boston, MA
2021 Taycan 4S, 2008 911 Carrera S Cabrio
I have the same problem. Also true if you have podcasts or Apple Music on. The phone connects and you get silence. The only workaround I have found is to turn off car play and use Bluetooth. It is annoying but I haven’t complained about it yet.
MrRothIII
North
Incoming: Taycan
Forum strikes again- had SXM the first day or 2 then noticed it was greg the last couple of tries. Forgot to mention to dealer so searched here and boom - diamond button fix worked.
thanks!
Taycan_mjkh
Fort Lauderdale, FL
Taycan RWD Base
This fixed my issue. Worked perfect.
