Strong Chemical Smell
Skan
Skander
Qatar
Hi everyone,
I have 2020 taycan with 30k Miles.
Since 3 days a strong Chemical smell in the cabin. It remind me strong Glue like super glue brand.
Any idea please and advise.
Thank you
Jasper4S
Jasper
Netherlands
Did you try to set the air conditioning to recirculate? If the smell disappears, it is something outside of your vehicle. Your garage, for example.
Skan
Skander
Qatar
Hi, yes.
Nothing from the outside I m sure.
snstevens
Sam
Kirkland, WA United States
Chemical smells, especially a urine or ammonia-like smell can happen if the air conditioning evaporator tray is not draining. This is caused by a plugged drain duct. Here is how to test whether this is an issue. I looked online for instructions for cleaning the drain, but couldn’t find anything solid. Perhaps someone else can chime in (and there is always the option of having the dealer check the AC drain).
Quick AC Drain check
  1. Park on clean, dry pavement, preferably after the car has been out of the rain.
  2. Start the car; set climate control to LO/maximum cooling, with the blower at medium-to-high speed and recirculation on if available.
  3. Let it run for 15–20 minutes with doors closed.
  4. Look underneath the car for water dripping. You may need a flashlight and may have to look inboard rather than directly at the outer rocker panel. The Taycan’s A/C evaporator condensate outlet is not one of the six visible rubber body drain plugs. It exits from the HVAC case into the front underbody’s central tunnel area, roughly under the front passenger-footwell/HVAC housing area—behind the front axle line and ahead of the main battery tray.
  5. Open the passenger-side front footwell and feel the carpet and under-mat area for fresh dampness. Clear, odorless water appearing after A/C operation points toward condensate; coolant would usually have color/odor and requires a different diagnosis.
A healthy system generally produces a visible drip after sustained A/C use in humid conditions. No drip is not definitive in very dry weather, so repeat the test on a humid day or after a normal drive with the A/C operating.
