- David
- Jan 28, 2019
- Santa Cruz
once you're "below" 175 kW on the taper curve for the battery (about the 50-55% battery SOC point in the charge curve) - both 150 kW/350 kW charger are the "same" speed for the remaining duration of the charge session…
so the only "advantage" 270/350 kW charging can offer is the battery SOC range prior to the point where we're are at about 175 kW and decreasing…
50% is about 42 kWh
and to make the math even easier we'll assume you're starting from effective zero:
270 kW charge rate is 270 kWh for one hour of charge
42 / 270 = 0.155 or about 16%
16% of 60 minutes is 9.6 minutes to provide 42 kWh @ 270 kW
42 / 175 kW = .24 or about 24%
24% of 60 minutes = 14.4 or about 15 minutes
time to provide 42 kWh @ 270 kW = 9.6 minutes
time to provide 42 kWh @ 175 kW = 15 minutes
time saved for 270 kW vs. 175 kW = 15 - 9.6 or about 6.4 minutes - call it 6 1/2 minutes
basically 270 kW is only "faster" than 150 kW for the 1st 1/2 of the battery - after the battery is half full due to the charge rate taper curve you are effectively getting less than the "full" benefit of 270 kW charger because the vehicle is reducing the charge rate as the battery gets closer and closer to full…as the battery charge rate approaches 150 kW it equalizes the slower and faster charging stalls because while a charging stall can provide 270 kW charge rate - the vehicle can not accept that rate for the entire charging session.
the simplest model is: you get the "fast" rate for the 1st half of the session - and you get the "slower" rate for the 2nd 1/2 of the session
the maximum optimal ideal theoretical savings for 270 kW vs. 150 kW charging is 6.5 min for the 1st half of the charge session - after that 1st 1/2 the extra speed advantages diminishes for the 2nd half - and by 90% SOC you're charging at below 50 kW…regardless of which type of charging stall you have selected
math + fast-charge-taper-curve - means the difference between two operational ideal stalls - one at 350 kW and the other at 150 kW is about 8 minutes best case…to 90-95%…with the main advantage all being delivered in the first 42 kWh - after that point charge taper curve equalizes the performance of the two different speed stalls…
50% is about 42 kWh
