Taycan CT turbo tyres
Taycanistra
Alex
Istra
Taycan CT Turbo
Hi to all of you.
My question is, can I put 315/30/21 and 275/35/21 instead of 305/30/21 and 265/35/21?
prj
Estonia
www.mapev.net
Taycan CT 4 - 2026
Hi to all of you.
No.
The 265/35 already rubs at full lock in the front. Also the height is a % of the width. A 275/35 100% will never ever fit in the front.
Rear probably the same story.
MrJones02
Germany
275 tires can have different tread widths, with some close/same as a 265 depending on the brand/type.
I think it might work if you pick a 275 tire with the lowest tread width?
tirerack for example will list the tread width for each tire
The height difference is very small
prj seems to be confident it wont fit, he's probably right then :)
RAHRCR
Northeast, US
Taycan Cross Turismo 4S
I had the 315’s on the rear of my Pan ST. It’s a LOT of tire. Wouldn’t make sense on daily driven EV.
Fogsvans
Sweden
Taycan Sport Turismo
There is more room to play with on the rear but the front is very tight. going from 265 to 275 adds 5 mm on each side of the wheel. On the other hand, 20 inch wheels with 245/45 have 30 mm larger diameter than your proposed 275/30 and they don't rub anything.
StellarOats
Los Angeles, CA
2021 Taycan Turbo S
prj
Estonia
www.mapev.net
Taycan CT 4 - 2026
I had 265/35 on my Turbo S CT and at full lock they were rubbing. Original Pirelli.
I then fitted Hankook ION and they were not rubbing, or barely.
The 275 most likely rubs quite heavily at full lock.
Detect
Detect
Taycan Turbo S, BMW i4
some of us run a square 285/35r20 for a track setup
