Taycan OBDII, Elm327?
Taycan4S
Norway
Taycan 4S, ex 964 C4,
Curious as I am, I tried connecting a Elm327 WiFi device to the OBDII port in the Taycan. Needless to say that didn’t work. It gets power and starts the WiFi but apps are not able to read values.
I’ve since read that some new Porsches do not use the standard signal pinout for the Elm327 interface.
It seems you need to swap the Porsche k-line to the vw k-line position. (Porsche on pin3, vw on pin7), according to this thread on rennlist:
https://rennlist.com/forums/cayenne-955-957-2003-2010/1047135-vcds-how-to.html
Does this apply to all new Porsches? If so, most likely to the Taycan as well?
Cpoarchy
Kentucky
1999 911, taycan 4s
I am curious, what is this device for?
Taycan4S
Taycan4S
Norway
For reading information from the car. Fault codes (reading and resetting) and general technical information from the car. It is what Porsche techs use on other Porsches and supposedly the Taycan as well.
rowi
Rolf
Germany, Cologne area
Taycan 4S, MY 2021
Are you a step further now? I don't know if the (very old) K-Line still exists in the newer cars. I do have a VCDS from my Audi days, but I don't know if I can at least read the fault codes (will need to set up Windoes again on my MacBook just for testing this out).
benver
Ben
the Netherlands
MY2020 Porsche Taycan Turbo
I also have an OBDII dongle, used it in my Opel Ampera(=Chevrolet Volt) for years to feed Torque Pro with data. Someone created a modified setup for Torque Pro for the Chevrolet Volt, which worked perfectly.
Of course I tried the dongle in my Taycan, but right away I got a message that the high volt system was switched on(or similar words), so I pulled the OBDII dongle out of the socket again and haven't tried it since.
I have done searches on internet, but haven't found an OBDII dongle for the Taycan that might work.
Tincan
Seattle
CT4
(found this via google)
I'm starting to have a look at what's available on the CAN buses of the Taycan, and this message pops up when you send a CAN message on the OBD port when the vehicle is on. It's just meant as a warning for a service person that would have diagnostic equipment connected, to let them know the car is on
jasperp
jasper
Flanders
tesla,porsche
I tried with a maclean odb2 dongle, but it did not work.
