Tire Pressure Readings Wrong
Dufferman12
Jeffrey
New Mexico
2020 Taycan 4s, 2018 9114S Targa, 1911 Model T Torpedo
I have a 4S and am having repeated troubles with tire pressure warnings. They say my tires are low on pressure but my check by accurate gauge shows that to be wrong and the pressures are right. Thoughts?
Jeff
SergeyIndy
Sergey
Indianapolis
We have seen this happen a few times on the forum. The recommendation is to let the TPMS system go through the learning cycle by switching the tire type to a different type and then switching back. If this does not work, then there is something wrong with the TPMS sensors or the system itself. I have noticed that when tires are replaced or interfered with, usually by a non-Porsche shop, when doing wheel refinish (for example), TPMS sensors can get damaged and need to be replaced.
jsigel
Northern California
2021 Taycan 4 Cross Turismo, 2006 911 Carrera S
This happened to me recently and following the advice above resolved the issue. It started doing it after I had it in for service (nothing tire or wheel related). Not sure that had any thing to do with it but relearning the pressures by switching wheel size fixed it.
