Transitioning from Taycan to Etron GT
Mr.Smith
PaulS
Southern California
So I found some hard data to compare my impressions with. There is common data for Vairano Handling Course for the TTS and the RS Audi. TTS finishes the course in 1:15 and the Audi completes it in 1:17.6. So TTS is definitely slightly more capable which makes perfect sense. This can also be seen in the breaking distance for the two cars, 140 kph is 222 ft for TTS vs 231 ft Audi.
TTS is the more capable track car by a small but significant bit (if you are on a track) but for me these differences will never show up in aggressive daily driving.
Realistically on the track I'd take the McLaren 570, which does the same course in 1:12.7 (a bigger gap than the one in between the two cars). Or the 718 Spyder (1:14). Not to say its not amazing that either of these heavy EV sedans being in competitive range of track performance.
There is the RS that has the optional upgraded carbon ceramic brakes like your Year one ( Vorsprungor over seas) or the standard tungsten carbide. Do you know which one it had?
The Taycan Turbo, without PDCC is a more accurate comparison.
I also find it interesting that Audi didn't offer their version of PDCC on the RS E-Tron GT. I'm sure that will help
As cool as it is to have an EV on the track, other than one time to try it out, it's nothing I would do, nor do I see the purpose of it. I agree a 718 would be a better fit.
An EV can only hide the weight to an extent. Taycan with PDCC is as good as it gets for now until the Mission R is released.
epirali
Edmund
USA, East Coast
I can't find out, but that is a good point. I wasn't sure why by their numbers the RS Etron GT needed 5 more feet to stop, must be the standard breaks. Still the point is the same (which is what you were saying), if for track use I would lean towards the Taycan TTS, but for non track, for me, I prefer the 4S or Audi.
I have a feeling that VW/Audi/Porsche did not push the car to match the Turbo S.
As for the Mission R I will say something that may be sacrilage for some: I don't think I need ANY MORE horsepower. I am not waiting for small/low weight...
Mr.Smith
PaulS
Southern California
VW is making something for everyone, with minimal overlap.
That's why they will be the top of the EV class.
The mission R might be the one that has the focus on weight due to the new battery tech.
For HP it has to be up to what the individual finds "fast enough" for their personal taste.
HP wars are never ending, there is no finish line.
epirali
Edmund
USA, East Coast
Ok I'll propose an ending point: when you start needing special suits so your field of vision doesn't narrow on launch!
Mr.Smith
PaulS
Southern California
As an audio guy and knowing that cars are not the ideal environment for the best sound, how does the Taycan compare to the E-Tron GTs sound system?
epirali
Edmund
USA, East Coast
Thanks for the setup! Well its an unfair test for me, I went from the Burmeister from my TTS to a Harmon Kardon on the Audi. I have generally been a fan of Audi HK audio systems, they have the same level of care and quality as the rest of the interior. But compared against the Burmeister, well let's say it doesn't have a chance.
I ABSOLUTELY avoid any Audi with the Bose option, but that is because of Bose. The HK sound very good, and in fact is all you need for a car. But its a step down from the Burmeister. Then again I was telling my friend as much as I preferred it I don't think I would check the $7k+ option to get it if it wasn't already packaged because of the same reasons I have said before: a car is not an ideal listening environment.
Mr.Smith
PaulS
Southern California
The Audi has the B&O. Is that the same as HK?
epirali
Edmund
USA, East Coast
nope, you are correct, just misspoke. i keep flipping the name of those two companies in my head. Thanks for correcting. Old habit.
epirali
Edmund
USA, East Coast
So I listened to more reference stuff I have, the B&O is pretty good all in all. The main thing is to turn the treble down one notch as the treble is not as controlled as it should be and bump up the subwoofer one notch and TURN OFF all 3D and surround.
epirali
Edmund
USA, East Coast
Two big definite wins in my book in the Audi column:
1) The rear trunk CLOSES SILENTLY WITH NO BEEPING! Hooray! I know outside of US this is not a feature, but as minor as it was its was irritating....
2) Tire temperature readings in sports mode. Boy I never understood why Porsche doesn't do that in cars like the TTS and the 718 Spyder. Yes they are not perfect, and people started hurling insults in another Porsche forum because I pointed this out, about how no other real sports car has them (which is actually not true). Its very nice to have as a data point, specially with summer tires in colder temperatures and when pushing the tires hard.
Genau
Reston, Virginia
BTW the trunk close beeping can be disabled in the Taycan by your mechanic using PIWIS to alter a setting.
andrewket
Andrew
Vienna, VA
A friend of mine bought a launch edition RS and he took me for a brief ride a few days ago. The rear camera view is 3x better -- it looks normal like every other car on the road. I prefer the Taycan's interior, but I could see the RS appealing to a younger crowd (I'm 48). The UI looked a bit cleaner but I didn't spend much time with it.
epirali
Edmund
USA, East Coast
Another quick update now that I have more stick time with the Audi. Overall I love the car, can't find many flaws with its chosen balance of character. I still remain convinced that neither car is "better" or "worse" thankfully they are two different takes on the same incredibly well executed platform. It does come down to what your tastes, likes and even brand loyalty is.
I am now even more convinced that in speed and overall capability the Audi is on par with the Taycan. Not exactly as capable but close enough that for anything but a track it doesn't matter much. But here is what is confounding me. I personally have never had an experience where how the car "feels" as to its capabilities has been this decoupled from what it can do in this direction. I have been in plenty of American "sports" cars where they "feel" capable and then suddenly you realize its all show, that when you push them they fall apart quickly (I am also looking at you my Tesla Roadster, my ruined Lotus!).
This one is the other way. Because of how it feels more GT it "feels" like it shouldn't be able to come close to the Taycan TS. But its faking it. Every time I push it it just handles it. This is not about the speed, that feels the same in Dynamic mode (the comfort mode beautifully curves the throttle so you have speed but can just cruise along). Its the suspension and the handling. It makes sense, its the same basic set up, weight low, big tires, same positioning etc.
Still an interesting experience.
Mr.Smith
PaulS
Southern California
To your point about suspension and handling, here is an comparison by Chris Harris and how the Etron GT has different driving dynamics than a traditional Audi
Here is a comparison of the two.
