- Adrian
- Jan 11, 2021
- Aberdeen, Scotland
- 992.2, ex GTS ST & 4S owner, Macan T
So I get this issue if I try to close the trunk without having the key present in my pocket. Some kind of safety measure I think.When I use the lock button to close the trunk it usually stops while it is on its way down without any audible warning. It just stops and I have to use the other button to close it or just push it down with my hand. Then I can lock my car with either using the key (very annoying) or walk to the side and press the sensor in one of the door handles. My car has comfort access.
It happens 70% of the times I use the lock button. Usually the key is in my pocket and I am standing next to the trunk.
Does anyone else has this issue? I had the same problem with my 2015 Macan but only 10% of the time. It is not nice to see the same issues in a car that is 5 years newer. Non of the other brands I have owned had an problem with the trunk close&lock button.
The beep only occurs when using the foot gesture
