Can’t close trunk from PCM or with key
ardevd
Norway
Taycan GTS
Had my Taycan for a month or so now and noticed that I couldn’t close the electronic trunk with the key, only open it. At first I thought that’s simply how it’s designed but then I noticed yesterday that I can’t close the trunk through the PCM either. Tapping the trunk close button in the lower screen does nothing.
Anyone else experienced anything similar?
Iben
Jean-Are
Norway
Porsche Taycan Turbo GT (2025 mod.)
Just hold the button in (a few seconds)
Also if you have the Comfort Pack, PVTS+ tracker fob / key in your pocket, press close / close & lock and walk away the trunk will only close partially so ensure you hang around or stay in near proximity to ensure closure.
ardevd
Norway
Taycan GTS
Am I supposed to be able to close the trunk with the key though? I tried holding down the trunk-button but nothing happened
Nope. But if you have the Comfort Option then there are 2 buttons on the trunk - both close and one locks the car.
Midlifecrisis
Worcestershire
I couldn’t close mine last week from the PCM then it worked fine a few days later. Probably a bit temperamental like most of the electronics! Sadly you can’t close Porsche boots from the key (unlike Land Rover - but I will still keep the Porsche!)
submatrix
2021 Taycan
Damn, that's Good to Know. I've often wondered about this myself. Thanks!
Edit: after reading until the end of the thread I see that apparently this does not work :(
ardevd
Norway
Taycan GTS
It works from the PCM, just not the key fob.
Porsche care more about safety than LR ?
Midlifecrisis
Worcestershire
I’m not sure there is much of a safety issue closing the boot from the key! There are some things LR do better but it still doesn’t make me want one. My wife loves hers though
