Trunk Taycan vs Cross Turismo
salis
Mercedes CL500
Hi guys, I have been watching videos showing the trunk of the Taycan and the Cross Turismo and it seems the trunks are both the same size - the Cross Turismo obviously having the extra bit of space above the trunk cover, is this largely correct? So if you keep the trunk cover in the Cross Turismo, you have almost the same sized trunk as the Taycan (obviously easier to load/unload)?
Thanks in advance!
B61
Bine
SI
yep, the size is the same, but turismo has more space for (un)loading.
(edit: has, not have)
Jrkennedy37
Dallas TX
I don’t think that’s accurate. The published cu ft or litre measurements for the cross turismo are based on the space under the “shelf” which is the cargo cover.
Porsche lists RWD trunk at 14.3 cu ft and cross turismo 4 at 15.8 - the CT measurement does not include the air space above the shelf which should be at least another few cu ft.
Edit: Addressed in this thread as well: https://www.taycanforum.com/forum/threads/cargo-capacity.4785/#post-66482
B61
Bine
SI
I stand corrected :angel:
I haven't checked numbers, I just remember a comment from youtube comment about "the same trunk, but easier to (u)load...
Jrkennedy37
Dallas TX
Definitely not a surprise that the youtuber/comment oversimplified it. It happened in a few ways with the Panny ST as well:
1. "The ST has less than 2 cu ft more than the sedan, why would anyone get the ST!?" Well the space above the cargo cover wasn't included in the ST measurements ?‍♂
2. If you read comparisons from some of the biggest auto publications when the RS6 was launched, they all dismissed the PST as having too little cargo space without actually measuring it themselves or realizing that they were comparing two different standards. Made zero sense to me, and I never saw a correction - it seemed to be part of the narrative to elevate the RS6 further (as if it needed it!).
As someone with three large dogs, these details mean the difference of driving an engaging car/wagon vs a tall SUV.
B61
Bine
SI
Agreed.
But with three dogs, it's hard to believe that Porsche has a car for you :giggle:
FredC057
Fred
Brussels
Taycan Cross Turismo 4S (2022), Fiat 500Ce
Here is a picture with the shelf
Porsche Taycan Trunk Taycan vs Cross Turismo E1AFC70B-0DB7-44FB-88D1-EE75CC7FCB85
and without
Porsche Taycan Trunk Taycan vs Cross Turismo 1BF833BA-0595-4CBA-B52D-9CA25E4AD0D1
A normal Taycan was next to it and visually you can see that the CT has more space and accessibility.
And if you don’t option the Bose, you’ll get even more space in the hidden compartment underneath.
pEAkfrEAk
Germany
Porsche Taycan GTS [MY2023]
Exactly. The CT has a little more width and is easier to access
Porsche Taycan Trunk Taycan vs Cross Turismo Normal_vs_Kombi
salis
Mercedes CL500
and without
I thought even if you get Bose, you have the empty space underneath the boot where you can store the cables?
salis
Mercedes CL500
and without
I thought the cable compartment underneath the boot is always available, with or without Bose - please see below a screenshot from another forum thread - I have circled this compartment in blue:
Porsche Taycan Trunk Taycan vs Cross Turismo 1625037854367
FredC057
Fred
Brussels
This space always exist, it's bigger if you don't option the Bose or Burmeister.
If you option one of those, there is space just for cables, if not, you can put a soft bag.
Boot capacity:
Taycan 407 l
Taycan with Bose 366 l
Taycan CT 430 l
Taycan CT with Bose 379 l
The front boot is always the same = 84 l
So the CT is adding 23 l and easier access.
And the Bose is removing 51 l but it's underneath so not usable for all usage.
I like this space as I'm using it in my current cars to fit my shoes, cables, snow chains, ski boots or other things like that, so I didn't option the Bose. But I understand that for others, the quality of the sound is more important and their dog won't fit in that space anyway, it's good to have the choice, I would have chosen the Bose if it was not removing any space.
salis
Mercedes CL500
This is really helpful, thanks! Do you happen to have a photo of this space without the Bose?
Jrkennedy37
Dallas TX
Boot capacity:
Taycan 407 l
Taycan CT 430 l
CT also has additional capacity above the shelf/cargo cover. That volume is currently unknown from what I’ve read.
