- David
- Jan 28, 2019
- Santa Cruz
that’s not quite how it works - ALL J-1772 chargers advertise to the car the maximum rate (in amps) they support - if the J-1772/Tesla charger is installed correctly it will only advertise the rate that matches the appropriate amps to match the breaker.
if you think about it this is how it has to work - because a “public” L2 charger at the mall would have the same problem - i.e. the Taycan trying to pull more power than the public mall charger can offer (typically 30 amps)
J-1772 EVSE’s really ONLY do 3 things (they are not magic or complicated)
Tesla Gen1/Gen2 Wall chargers have a rotary “dip-switch” inside unit - it’s the job of the installer to setup this dip-switch to match the breaker for the installation. The range of AMP’s is like 20-100 amps and documented in the Installation guide for the Wall Charger.
for $500 the Tesla Gen2 Wall charger was one of the best values for an EVSE on the market and offered a range of 16-80 amp charge rate - it was a deal.
The Taycan will only pull the amount of power/amps advertised by the J-1772 charger it’s plugged into. Your 19.2 kw (80 amp) Taycan will only pull 48 amps on your Tesla Charger, and only pull 30 amp @ the mall plugged into a ChargePoint L2 charger…for our friends outside of north america - at least on the west coast most public L2 chargers are 240 volts @ 30 amps or less - so for most EV’s sold if you ever plugged into public non-fast charging you are plugging into a charger that has less possible power than the car can “suck” - so the maximum charge rate is dictated by the EVSE, and the EVSE advertised that rate - I once plugged in my 80 amp capable 2014 Tesla P85D to a 8 amp public charger in San Luis Obispo - it was painful, but the car did charge at 8 amps…not it’s maximum 80.
- safety relay - only let power flow _IF_ you’re actually plugged into a vehicle
- advertise a maximum amp rate to the vehicle
- respond to the vehicle telling them to turn power flow on/off
