Will leaving car in extended LIFT mode while parked cause issues?
Gordy
Scotland, UK
I need to use LIFT mode to get my car onto my drive, once parked up I don't lower it back down to Normal height as it needs LIFT to then get back out of driveway.
Does anyone know if leaving car in extended LIFT mode whilst parked would cause any problems with any suspension components or is it perfectly fine/safe to do so?
I can't imagine it would cause any issues but just wanted to check.
Thanks
No it shouldn't be a problem. I use Smart Lift and generally leave the car in the raised position (programmed for a series of speed bumps) until I next use it when it will automatically reset to normal when on the move. Not on an incline but don't see how that would matter at all.
NC_Taycan
Lewis
Wake Forest, NC
I've been parking in max height in the garage since April, with no issues. The Tesla would lower itself all the way to low height after a time. I don't know if there was a good reason for that. It's just air in cylinders. They shouldn't care how much air.
+1 for the car not looking so great when lifted though. But that extra 1.5 inches or so - definitely feel it in the knees when egressing...
NC_Taycan
Lewis
Wake Forest, NC
What if you were parked over a curb stop? Would it lower itself onto it and wreck your bumper?
It would rest on the curb. Or wheel stop in a parking lot. But after 8 years and 90,000 miles the behavior never caused damage that I was aware of. Then again, after I noticed the behavior I was more aware not to park where lowering might cause an issue...
Unlikely. Depends on height of curb. Car maintains its height but will attempt to auto level at a guess.
Bavlos
Taycan Turbo ST (on order)
Is it possible to have the car lift on the way into the drive and lower once parked….and then lift again when I get back in to leave?
Sort of, but not a seamless operation. There is no smart function for this. The random option is to set Smart Lift to ‘lift’ on approach to your drive but likely you would then have to manually lower the car (or accelerate to 15 mph - 20 mph to automatically lower the car to normal height (if your driveway length permits)). On exit, set Smart Lift to raise at a certain different point (again if driveway is long enough to get a different set of co-ordinates) and then once you reach the 15 mph - 20 mph limit the suspension will lower to normal height again..
Bavlos
Driveway is really short… so I’m guessing it will just stay lifted while parked which seems a shame
Oink
Norway
Taycan 4S+, M3P
Been doing that for a year at home. No issues.
Lift is just as ugly as lowest, at least on 20". Wheels go in and under the wheel arches so it looks weird. :p
atebit
Bob
PA
As you get older, comfort >> important than how it looks “raised”. ?‍?
Taycan_friend
Germany
Thanks
No, there will be no damage on parts.
