Administrator
Administrator
Key Highlights:
GTS Sedan starting price: $131,400
GTS Sport Turismo starting price: $133,300
$1,350 delivery charge
Available to order now
U.S. deliveries start Q2 of 2022
590 hp
0-60 mph in 3.5s
93.4 kWh Performance Battery Plus
Charging speed up to 270 kW (from 5 to 80 percent in 22.5 minutes)
Suspension carried over from Taycan Turbo S, but with GTS bespoke calibration and tuning
All standard and optional performance features have been massaged.
Standard braking system shares same red six-piston front caliper and four-piston rear caliper as the 4S, but is equipped with larger 390 mm front rotors (vs 360 mm on the Taycan 4S).
The rear rotor size is the same as the 4S, at 358 mm.
Porsche Surface Coated Brakes, with tungsten carbide coating, and Porsche Ceramic Composite Brakes are also available.
Porsche Electric Sport Sound tuned to be deeper and louder for both bystanders and passengers alike.
Full press release:
2022 Porsche Taycan GTS Sedan and Taycan GTS Sport Turismo
11/16/2021
New performance model and Sport Turismo body style debut
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo TA22Q2AIX0001_highres
No matter the form of motive power, the GTS variant of any Porsche is the optimal combination of performance and luxury, without sacrificing everyday usability. The Taycan GTS sedan and Taycan GTS Sport Turismo exemplifies this distinction. Enhanced styling and performance as well as unique suspension tuning and Electric Sport Sound among an array of changes that denote that this is the first electric GTS.
Pricing for the Taycan GTS sedan starts at $131,400, while the pricing for the Taycan GTS Sport Turismo will start at $133,300. Neither price includes $1,350 delivery, processing, and handling fee. Both Taycan GTS models are available to order now and U.S. deliveries will start in Q2 of 2022. EPA range and consumption figures will be available closer to delivery.
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo W21_8327_highres
Similarities
The Taycan GTS sedan and GTS Sport Turismo feature the same permanent magnet single-speed front motor, larger permanent magnet rear motor with a diameter of 245 mm and an active length of 210 mm, and two-speed rear transmission. This setup provides a total power output of 590 hp with Launch Control, slotting the GTS models in between the Taycan 4S (462 hp) and Taycan Turbo (670 hp).
Much like the Taycan Turbo and Taycan Turbo S, the Taycan GTS comes standard with the 93.4 kWh Performance Battery Plus and its 800-volt architecture means it can handle continuous demand while minimizing heat build-up. This translates to high charging speeds of up to 270 kW and is part of the reason it can charge from 5 to 80 percent in 22.5 minutes, while accelerating both variants from 0-60 mph in 3.5 seconds.
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_004_highres
Taycan GTS
Inside the Taycan GTS, the familiar multi-screen dash and ergonomic and sporty seating position remains. And many of the standard technology and comfort features from the other Taycan sports cars, such Apple CarPlay and Android Auto, automatic climate control, Porsche Connect with Porsche Charging Planner also come standard in the GTS variants.
Differences
Although numerous components of the Taycan GTS family are inherited from the top-model Taycan, there are notable differences. Visually, the GTS wears the SportDesign front fascia, and the SportDesign side skirts and side window trim in high-gloss black. The rear diffuser features a high-gloss black inlay. The side skirts feature GTS logos, and the badging on the rear is in matte black. The standard 20-inch Taycan Turbo S Aero Design wheel features an exclusive satin-black finish, and the rear light strip features the Porsche logo in black. Finally, the LED-Matrix-Design headlights with PDLS Plus are tinted in black, and the exterior mirror cap-bottoms are painted in body color while the base is in black.
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2_Taycan_GTS_Sport_Turismo_Carmine_Red_019_highres
Though the suspension and performance equipment is carried over from the top-model Taycan, the calibration and tuning are all bespoke to the GTS. All the standard and optional performance features have been massaged to make the car even more responsive and connected to the road than before. The standard braking system shares the same red six-piston front caliper and four-piston rear caliper as the 4S, but is equipped with larger 390 mm front rotors (vs 360 mm on the Taycan 4S). The rear rotor size is the same as the 4S, at 358 mm. Porsche Surface Coated Brakes, with tungsten carbide coating, and Porsche Ceramic Composite Brakes are also available. Even the Porsche Electric Sport Sound has been tuned to be deeper and louder for both bystanders and passengers alike.
Standard performance features include Adaptive Air Suspension with Smart Lift and Porsche Active Suspension Management, Porsche Torque Vectoring Plus and Sport Chrono Package including the GT Multifunction Steering Wheel and Mode Dial. Optionally available performance equipment includes Porsche Dynamic Chassis Control Sport, Rear-Axle Steering, and 21-inch RS Spyder Design wheels in satin black.
Interior
The Taycan GTS features a unique Race-Tex interior package that reflects similar treatments from other GTS model lines. Driver and passenger seats feature 18-way electric adjustability and memory functions with “GTS” logos on the front and rear headrests. The door sill guards and interior trim is in brushed black aluminum and the accent package is in black. Roof lining and steering-wheel are also covered in Race-Tex.
Optionally, an available GTS Interior Package includes deviated stitching in either Carmine red or Chalk on the dashboard, doors, armrests, steering wheel and seats, with matching seat belts, “GTS” embroidery on the front and rear headrests, Sport Chrono instrument dial and the Porsche logo on the floor mats. The trim on the steering wheel, center console and door trim are in matte carbon.
New Sport Turismo
If the Taycan Cross Turismo exemplifies all-weather, all-road capability, the Taycan GTS Sport Turismo sharpens the focus for the road. With the same interior dimensions as the Taycan Cross Turismo, the Taycan GTS Sport Turismo maintains the 15.7 cubic feet of rear cargo volume in the rear. Fold the rear seats forward, and a total of 42.8 cubic feet is available. Like the sedans and Cross Turismo, the GTS Sport Turismo also features a 2.9 cubic foot front trunk.
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo W21_9036_highres
Panoramic Roof with Variable Light Control is available as a new optional extra for the Taycan GTS.
Like the Cross Turismo, the Taycan GTS Sport Turismo will also feature a glass roof and hard points to mount a Tequipment bike rack on the rear of the vehicle. Optional equipment includes roof rails, and an all-new Panoramic Roof with Variable Light Control. This system allows the driver to adjust the amount of light by activating nine liquid crystal film segments in the roof, much like a digital clock. There are four preset patterns, clear, matte, 40% (Semi), and 60% (Bold). Or each individual segment can be activated from the PCM. When the vehicle is switched off, the roof automatically switches to matte, and once restarted, the system will remember the previous roof setting. This option is also available on the sedan as well.
Visually, there are additional cues that separate the Taycan GTS Sport Turismo from the existing Cross Turismo family. The rear spoiler is paint matched to the body color, and there is no cladding over the wheel arches. The ride height for the Taycan GTS Sport Turismo is shared with the sedan, lowering the center of gravity even further.
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo W21_1279_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo W21_8190_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo W21_8503_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo W21_8977_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo W21_8681_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo W21_0970_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo W21_8784_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo W21_8855_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo TA22Q2BID0011_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_030_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_031_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_033_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_001_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_009_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_014_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_016_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_020_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_021_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_029_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_034_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_036_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_037_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_039_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_041_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_044_highres
Porsche Taycan ? World Premiere: 2022 Taycan GTS Sedan and GTS Sport Turismo 2022_Taycan_GTS_Chalk_045_highres
Yves_0016
Antwerp, Belgium
2021 Porsche Taycan 4S Performance Plus
Love the interior. Alcantara/race tex. Very, very nice.
Not a fan of the black stuff on the exterior. I have the same feeling with all Porsche GTS models. I seem to be in a minority on this. To each his own I suppose.
Ireland
Taycan Turbo S, Fiat 500 EV
Will those wheels be an option on other models or GTS exclusive only ?
Any idea of the power without Launch Control on the Sport Turismo GTS? I've been waiting for a Turbo CT allocation for months now, perhaps this would be a good alternative to get one sooner? I am only interested in power without Launch Control, since I never see myself using Launch Control - I want the power for higher speed acceleration.
mdrobc1213
Atlanta
BMW M4, Taycan CT4, 992 Carrera,
Agrh...Just when my CT-4 has finished production! :(. Porsche you're killin me Smalls!
CanuckRacer
Mark
Victoria, BC
Porsche Taycan 4S, Mazda RX-8, 1929 Studebaker
Hmm, geez they just announced the Cayman GT4 RS too... almost missed this!
At first blush, I'm slightly confused - it looks like mostly a badging and options package, with a tad more power (would you even notice it?).
Does it come with all the chassis performance goodies standard (Performance Package in Canada)? I'm guessing yes.. no Canadian pricing as of today on Porsche's website..
Pozuelo
Roberto
Madrid, Spain
2020 Taycan Turbo S, 2018 E63S Estate, 2023 A45S
Hope a Sport Turismo can be ordered in Turbo S guise as well. I would like to replace my 2020 Turbo S sedan and 2017 AMG E63S wagon with a 2023 loaded Sport Turismo next September ! Hope we can spec the carmine red seatbelts and a few new goodies not available when mine was produced.
goaroundnow
Ben
London, UK
Taycan 4S CT
Yes, sorry - was a stupid question really. I just could not see it on the UK Configurator yet
