22 Taycan 4S Range Change
Cacofonix
Simon
Taycan ST 4S
I took delivery of my second Taycan, a 4S Sport Turismo (PB+ on 21 alloys) on 23 Dec 22. I was surprised by how low the range of 200 miles was given my first Taycan, a 4S Cross Turismo on 20 alloys which I took delivery of in January 2022 never showed a range below 230 (270+ during summer).
I found on this forum the issue of no regen until the brakes are bedded in and realised that the regen had started working on the CT straight away. I have been doing extra braking in the new ST since then and at 570 miles on Saturday the regen suddenly showed green on the power meter. I then recharged the car yesterday but the range is still only 195 miles.
Does anyone know if it takes time for the regen to build the range back up to something acceptable?
Activation of recuperation doesn't trigger an additional range estimate. One is not dependent on the other. This comes with miles added and higher ambient temperatures.
Recuperation is more to do with range extension whilst on the move not whilst standing still after a charge.
Look at your consumption data and then calculate what that means in terms of actual range (remember to use the net battery capacity and not the gross).
Cacofonix
Simon
Taycan ST 4S
It's not pretty, 664 miles over 36.4 hours, average 2.1m per kwh; on 86kwh net capacity that's 180 miles! It's like I didn't get the PB+
Archimedes
Monterey
I’m coming up on 10k miles and I’m convinced that stuff like range mode, recuperation, etc. have only a small impact on range. Low temps and running the heater/defroster, on the other hand, seem to hammer range.
Correct!
Range mode is almost redundant now as the car is predominantly RWD most of the time in AWD models. Single digit range increase.
Recuperation - unless driving like a maniac uses more energy than it gives back in my experience. Coasting is better when able.
Thorgal
Volvo XC90T8 - Taycan CT 4S
In my experience the guess-o-meter is actually a lot more accurate after the big update.
I also lost about 50km of range after the update, but now it is consistent with the consumption, before it was too optimistic. This winter up until now I get about 23 kWh/100km and the range indicated is 360km, which is correct. In summer I get more or less 19,5 kWh/100km so the range will probably increase to about 420km.
Archimedes
Monterey
Agree. Since I started using recoup a lot, my range has gone down slightly. When I first got my car, I never used it and I got 7-10 miles more range. Similar temps.
Cacofonix
Simon
Taycan ST 4S
I totally agree, but over 11 months of owning a 4S CT with 20 in alloys my average was 2.9m/kwh, I'm not sure I'm going to see anywhere near that with this new 4S ST with 21 in alloys. By the way I'm not talking about the active regeneration in my first post, it was about the regeneration that happens under braking where you're not actually using the brake pads (up to a point) but the regenerative electric motor braking that shows up on the power meter as regen.
