Guards Red Car
Connecticut, USA
2021 Taycan, 2021 Macan S, 2024 Boxster S, 2024 Cayenne S e-Hybrid
Hi Luke
I've been tracking my order (Cross Turismo 4S) through the Porsche Web Site - Initially my delivery was mid August and Now is is early October
My Order "Change Freeze Point" is 15 days from now
I am not in a rush to get my car - Winter/Spring would be acceptable
However, now that I'm looking a fall delivery of a Late Model Year 2021 - I would much prefer a 2022 Model (I see that there will be upgrades, albeit likely nothing major)
Question - Can I "push" my 2021 Model Year Cross Turismo 4S allocation forward insuring a 2022 Model Year? -- Or, do I "Resign" from my allocation (i.e. give it back to dealer) and hope he can move me into a 2022 allocation? -- Would a dealer give me the next available allocation (2022) or would I have to "get to the back of the line?"
Thanks!
Bry5on
CA
'70 electric Jaguar, ‘21 Taycan 4S CT
+1, same situation, same car, same timeline, same thoughts on model year
Simply ask your dealer to defer and see what the options are. It may mean forfeiting your slot but if not in a rush then no real issue.
Guards Red Car
Connecticut, USA
I waited this long, I have the dealer's first CT 4S 2021 Allocation.... I Want a 2022
2022
- Wired Android Auto, PCM Upgrades, Nicer Interior Bits, Parking Upgrades, Front Axle Decoupling....
My dealer tells me my build is definitely a 2021 (Deposit for a Cross Turismo over 2 years ago, Got my allocation in March - Change Freeze Point is in 10 days and Delivery now pushed back to October) - He will be happy to "take back" my 2021 allocation and put me on list for future 2022 - but, no saying if/when that allocation would be available
Frustrated, waited SO long and really wanted the freshest offering (apparently the 2022 configurator is a couple of weeks away!!) Just would have been a nice gesture if Porsche North America offered me the option of pushing my allocation forward to a 2022 model
SteveDC
Steve
Mid-Atlantic
Taycan 21 4S
Sure!
Frozen Blue Metallic vs Crayon (Chalk)
Very different colors, especially once they're on the car. Frozen Blue is almost like a Baby Blue whereas Crayon (Chalk) is closer to a Concrete kind of color...
My 4S is a Chalk. I would say the color is creamy taup. That’s the closest I can come to a description. There is a dramatic difference in bright sunlight. Under florescent lights it looks closer to a white. With sunglasses on while driving, it takes on still another hue. I’ve heard many new 911s are being clad in Chalk livery.
kort
'23 Lucid Air GT
the creamy color looks like coffee beige.
Chuck J
Chuck
AR
What do you know about the "sudden stoppage" issue including when dealers will be able to start putting in the software fix?
Thanks
Chuck J
Reactions: KTC
Jaydoc
Judith
911 Targa, Taycan on order
Thanks
Chuck J
WHAT????????????
Chuck J
Chuck
AR
Looks like there is a sudden stoppage recall coming out on the Taycan.
Chuck J
XLR82XS
LXA
SW FL | Vegas
Luke, couple of questions:
1) Normal for the transmission to occasionally clunk while driving? I have noticed this a few times on my RWD with ~800 miles. Deceleration, coming out of a corner when turning, once switching to sport mode at ~40mph.
2) Expanded map/map in cluster. 95% of the time the orientation defaults to 'direction travel' even when I set it to 'north up'. When I turn the car on it's set to 'direction' - maybe only after sitting for an extended time period. If I park then return to the car within a short time frame the setting is how I left it, 'north up'
buruburu
Sherman
Washington
Cayenne E-Hybrid, 718 Spyder RS
Clunking is normal because the Taycan uses a 2 speed transmission w/ a dog clutch. It's probably the only way for the transmission to not shred itself with the high electric motor torque.
https://www.peakresources.com.au/ne...aycans-engineering-designed-to-take-on-tesla/
Did you make the setting change in the instrument panel's nav settings or in the infotainment nav setting? They are separate from each other so try highlighting the navigation cluster in the instrument panel, then press the right scroll wheel to get the settings popup.
NC_Taycan
Lewis
Wake Forest, NC
I have noticed the transmission shift seems to feel like anything from a subtle clunk to a subtle grind, depending on the acceleration at the time. Harder acceleration seems to result in more of a crisp (clunk) feel, and softer acceleration seems to result in more of a stutter feel. Neither concerning, but the stutter is more obvious than the clunk. The obvious solution is to accelerate hard(er) whenever possible :)
J0EL
Y1ADB1
2021 Taycan 4S
Porsche has certified mechanical engineers.
Shouldn't they also have at least one certified electrical engineer at each dealer?:facepalm:
Its an "all electric car"
kort
'23 Lucid Air GT
my dealership experience has been terrible as has others, see the post of the guy from chicago.
the dealerships appear to be very poorly trained on the car.
when issues crop up they are stumped, resulting in long stays at the dealership or they are outright lying about what steps that they are taking.
porsche customer care is zero help, they are a black hole where complaints about the dealership's handling of issues go to die. there is zero follow up from them.
my car was in for a series of fail to charge events. they took in the car on monday, they were set to return the car on wednesday then they said that they need to hold the car because they received instructions from porsche germany on what steps to take.
I go to the dealership on friday expecting the car to be fixed but nothing was done.
the fix from germany was an outright LIE, they held the car two more days and did NOTHING additional.
why would they concoct such a fabrication? I am now forced to start building a case to get the car lemon lawed.
the level of service is terrible.
