Bognar67
- Janos
- Jul 9, 2021
- Hungary
- Taycan GTS 2022, i4 40 MS 2024, GT3 992.2 2025.
These are my side numbers low and high on DC Smatrics charges.Your experience at Smatrics, would mean you spent 75% more time with battery saving than without? Assuming there is no penalty for longer charging times.
It would mean that the charging curve would be significantly different in your two cases? Interesting observation and something I will look out gor next time.
Interesting pricing model to have it time based, especially if the charge rate would be less than expected. Say you should be able to get 250 kW but the station only delivers 100 kW. The you loose out?
I saw that the Porsche Charging Service was not active in a few countries in Europ yet, Poland, Hungary amongst them. Hope that will be sorted out soon.
Anyway these are my last charges without 1. Battery Saving (EUR0,33/kWh) 2. with Battery Saving(EUR0,51/kWh).
Not fully comparable (charging states and amounts, but same trip charges directly after each other so temp is similar preheat on both) but -on the pricing of minute charging method- I can feel the diff on my pocket.
