Tambrose
- Tom
- Apr 24, 2021
- Orange County, CA
- 2021 Taycan RWD
- #1
I just had my '21 RWD in for brake fluid replacement at 18.6K miles. I was informed that my tires were badly in need of replacement due to heavy wear on the insides (and a bit worse on the rears, which makes sense).
I had them replace the tires and do an alignment. The tech reported that the RF camber is out of spec due to the knuckle being bent. The LF camber is -0.52deg and the RF is -1.14deg. This is basically the same as it was prior to the alignment. The toe was also off a bit prior to the alignment, but is good now.
I've not hit anything during my time with the car.
The dealer is saying that this is not a big deal and can be left as is. He also pointed out that I'd have to pay for a new alignment in addition to the replacement cost. I'm not feeling overly comfortable with this, at least at the moment.
My questions:
- Is this OK to leave for now? Note that the car is leased and that ends in ~1 year.
- Could the knuckle have been bent when I got the car (it was new) and this is why I had the wear?
- If so, could it be under warranty?
- Any other thoughts on what I should do?
Thanks much!
My questions:
Thanks much!
