Car will only charge to 25%
ahmadcpa
Ahmad
Sunnyvale, CA
I pushed a button here or there and effed things up. What did I do that causes the car to charge at 25% only.? Tried Level 2 charges and at various locations including shopping centers.
bn8959
Ben
UK, South West
Taycan GTS ST (MY24)
This would happen if:
You had a profile enabled with the minimum charge set to 25% and optimum charge mode (not preferred time mode) enabled.
And, no timer enabled.
Try enabling Direct Charging - this should bypass everything and charge to 100% if it can. Same applies to any DC charging, that will always charge to until 100% (or disconnected).
SergeyIndy
Sergey
Indianapolis
This means that you have your Profile set to 25% with Optimized option as @bn8959 said.
You need to change that to something higher, or just use Direct Charging.
None of this applies to fast DC charging, which will go to 100%, so recommend finding one, unless of course you run into EA station that now limits everyone to 85%.
tkhelm
Troy
Seattle
I’ve had this happen when navigating home (where I charge) AND the nav didn’t turn itself off because it didn’t recognize that we had arrived (GPS reception at that location is weak). The next charge would only go to the % that I started at for that last nav trip. Makes no sense but it happened more than once. I just have to make sure I stop the nav session when I get home.
Actually, I ended up only using the Porsche nav for long trips where I need it to tell me where to charge. For everything else I use Google Maps in CarPlay.
glengarrygr
Chas
Atlanta, GA
991.2 S, Cayenne
May be dumb suggestion, but click vehicle, battery, then use your finger to slide the battery's target range up to 100%. Mine was stuck on 55% and this fixed the issue.
