Charger Problem
louv
Don
Maine
That could be very dangerous. Don’t use a extension cord, especially the ones that are rolled up. The cable will go on fire 100%
100%? No.
Chance of fire, if cord is undersized for amperage? Yes.
Extension cords generally a bad idea with Car Charging Stations: Yes.
feye
Shenzhen, Munich
Porsche Taycan 4S+ 2020
This charger only pulls maximum of 10 amps as its plugged into UK domestic socket outlet which isn't huge and is on a protected circuit. I find it strange that it would even start if it feels there is an earthing problem. This happens after several hours of charging. Will get it checked but I'd be very surprised if there's an earth fault as wiring is fairly new and tested.
Unlikely to ever use this charger again anyway as the 7Kw charger is being installed tomorrow.
A lot of small household appliances even don't have earthing cable, but they still trigger circuit breakers if they shortcut. Circuit breaking and earthing are two different things. There were electricians and home builders which were nonchalant when it comes to earthing.
Installing dedicated charger is def the way to go!
Gogs
Gordon
Aberdeen, Scotland, UK
Just to add my father plugged
100%? No.
okay no
100%? No.
okay not 100% But I’m trying to get my point across. Like you said bad idea.
