- Adrian
- Jan 11, 2021
- Aberdeen, Scotland
- 992.2, ex GTS ST & 4S owner, Macan T
Yeah was suspecting that might be the case hence suggestion to pursue the original approach.It is hard wired to a breaker located in the junction box, the Ohme Home Pro has the option of 5m or 8m tethered cable. So no option to use another charging device unless you get an electrical to remove the Ohme and install a commando socket which means you just removed a £1k Ohme install.
