Charging on Long Trips in 2026 Vice 2020
PSUEric
Eric
St Marys, Ga
2008 Infiniti G37S Coupe, 2015 Toyota Highlander
Moved this to a new thread:
I thought it would be interesting to review this great post from October 2020 and compare how things were then to today February 2026 regarding long trips.
First and foremost:
Folks need to understand that you NEVER travel anywhere NEAR your total range capacity as you may find that the entire charging station you planned to stop at will be completely unusable. This actually happened to me TWICE in the seven stations I had planned to visit (each way). TWO whole stations were completely down and phone calls to Electrify America could not get ANY of the charging terminals at either of the stations working (3 terminals at one and 4 terminals at the other)! You will likely want to have 50-60 miles of range in reserve in case you simply can't get a charge at a planned stop. Consider the density of charging options in the areas you will be travelling. You don't want to be forced to go backwards because the only station within your remaining range is behind you! (I always had the necessary range to make a secondary choice I had laid out further down the road). You REALLY don't want to be looking for a a car dealer (Chevy, Porsche, BMW), an RV park/campground, a Tesla Charger at a hotel, or be forced to plug into some 120V outlet cause nothing else is within range!
Mostly still true. While chargers are more plentiful and reliable and the Supercharger Network is now open to all, the chances of having to use a car dealer, hotel 2nd level charger or a 120V outlet are now in 2026 almost zero! It still does however make no sense to run the batteries close to zero.
Adjust your expectations:
My 700 mile trip (each way), which normally takes me 12 Hrs, took about 3 hrs longer with the added charging stops. That 25% percent overhead for an EV vs an ICE vehicle. Understand what it is you are getting into. This isn't the way I would normally drive (stopping so often). Accept it as an adventure if necessary. ...or skip all the challenges and take an ICE. (Not Kidding here!)
No longer agree that long drives are an issue. Driving straight through from Pa to S. Ga. (~850 miles) a couple times took me on average 30-45 minutes longer than with an ICE. The Taycan does charge from a fire hose and there are many more high speed chargers along the way than in 2020.
Preparedness:
Have a good travel charger in your car for the trip. I carry a Mustart Travelmaster(120/220) with several adapter cables (Nema 10-50 (RV), Nema 6-50 (Welder), Nema 14-30 (Drier), and Nema 5-15 (120V)). You might need a travel charger in an emergency if you can't get to a public EV charger. You may need to pick up an emergency charge at an RV park or garage somewhere.
I also have a 40ft J1772 extension so I can run a charging circuit from inside a house/garage/building. The 40 ft extension is for the car connector not the supply plug. This lets me keep the charger itself out of the weather and I can use it regardless of which adapter plug I have attached. This extension also makes it handy if you want to use a relative's drier or welder connection from a relatively remote location inside their home.
Keep a Tesla Tap in your charging kit in case you also need it in an emergency. You can't use Tesla SuperChargers with the tap but you can use lower power Tesla Destination Chargers found at many Hotels, etc!
Go out and run a test charge before your trip so you know what works and what doesn't. You don't want to be figuring how to activate a charger at Zero-Dark-Thirty some morning in the rain on your first trip. You need to establish a process YOU are comfortable with.
No longer agree. I read on the forums about the initial 2012 dave04EV Road Warrior charging kit (it was complete and allowed a BEV to charge anywhere there was an outlet!). By 2022 his kit was reduced quite a bit and by the time I received my car, my kit had been reduced to a Tesla Tap for hotels and the Tesla Adapter for Supercharger access. The Porsche charger that came with my car sits comfortably in my garage.
Planning:
Use ABRP (Web) to plan your route and charging stops NLT the day before you depart. (Its easier to do this using the Web app on your PC with a real keyboard and mouse). Figure out what stations you want to use. Consider where they are and how convenient they may be (rush hour around cities, etc). Consider if there are secondary choices further down the road and how far they are. If you have two possible stops 30-miles apart, plan to stop at the FIRST (nearest) one in case you have an issue and need to travel to the SECOND one. Make sure you are happy with your ABRP route before you go any further. Planning is everything! (Do NOT expect to rely on the onboard Nav system to plot your stops. You might have to use it in an emergency, but it makes unexplainable choices and I would never use it for planning).
Use PlugShare (Web) to confirm quantity/size/number/status of chargers at your selected stops. (IOW: Feedback from real users). Set yourself up with a free account so you can "Check In" on the road.
Use Electrify America (Web) to double check your "FREE" charger locations. Set up an account and you can also activate their charge points without having to rely on the "Porsche Connect" or "Charging NA" apps which are riddled with bugs.
Push your chosen Charging Stops down to your car as "favorites" for easy access on the road. Use the web-based version of the Porsche Connect to push all the charger locations down to your vehicle so you have quick access to them as "favorites". (You will want to use the web based version while you are still sitting at your keyboard). Here is how you get to the web based version of Porsche Connect: Log on to the "My Porsche" portal". (Note if you are a US driver and Porsche is redirecting you to the "GB" site for some STUPID reason, you will want to use this link instead.) Click on "Service Overview" (under your car). Hopefully you will see "Navigation Plus" in one of the service boxes. Once you click on Navigation Plus you should see a map. Click on Add Destination and type the address for the desired charging station. Make sure you mark it as a "FAVORITE" before you save it. The location will be transferred to your car! BUT! You are not done yet! (More Porsche Software Crappiness!). Once you get ALL your charger addresses pushed down to the car, you will now need to go out to the car and "convert" those addresses.
Convert your Charger Addresses so your Porsche understands they are actually charging stations (not just a mailbox). Go into your car and pull up each "favorite" in the Nav system. Even though it is the EXACT address of a charging station, you will have to select the option to "Find Nearby Charging Stations" and then select "Porsche Charging Services". Once you have done this, you can mark THAT EXACT SAME NEW address as a "favorite" and discard the original one you sent from the web. (If you don't do this, the Porsche Nav system may inexplicably route you to some OTHER charger miles away from the one you were right next to! As long as your "favorites" are known to be charging locations then the Nav system SHOULD use them as a charging stop (and also pre-warm your battery for optimum charging speed at arrival).
Partially agree. Still need to plan, but the onboard systems are for the most part much improved. I still use ABRP, Apple CarPlay and the Porsche PCM to plan. They use Plug Share to verify station ratings. It’s not yet Tesla easy, but certainly much improved over 6 years.
EnRoute:
When you first get in the car to begin your trip, put your final destination into the Nav system. After you specify a final destination, you can then add charging "stopovers". Luckily you now have them all converted and stored as favorites! You can add all your charging stops - but you must do this in reverse order - from the destination backwards (thanks @louv !). However, since you are going to have to fight with the Nav system as it continues to calculate and add OTHER charging stops as you try to enter yours, I recommend you initially add only your very first charging stop. This will get you out on the road ASAP. Once you actually start charging at your first stop, you will have plenty of time to fight with the Nav system and add the rest of them!
Here is a tip to help make the onboard Nav a bit more useful on long trips. There is a fairly useless insert on the Nav screen which will show you a green line and the next two charging stops you have scheduled. The thing is, it doesn't show you how far away you are from each of these stops. It only shows you how long you will have to charge at each stop. ...and clicking on this pretty useless screen does nothing to bring up any additional info. Similarly, the Nav system simply doesn't show you how far you have left to travel before your next charging stop (unless it is your final destination). Who designed/tested this crap? ...anyway, if you hit the three little dots on the lower right of the nav screen you will see an option to "Edit The Route". Normally, this is one of the places you would fight with Porsche to try and get all your charging stops in the correct order. If you select the "Edit Route" option, you will see that it leaves up your list of charging stops AND IT WILL CONTINUOUSLY UPDATE THEIR DISTANCE as you get closer. So, I normally put the map up on the center of my instrument panel and then leave the "Edit Route" screen up on the center console. Perhaps it would be better named "Display Route" instead of "Edit Route".
Use the Porsche Connect app or Charging NA app to activate your free charging sessions as you arrive at each charger. (Good Luck!) If you have an issue with the Porsche Apps just use the EA app and pay the price to skip all the headaches! I brought my iPad on the trip to compare the Porsche IOS apps vs the Porsche Android apps. The IOS stuff works more reliably than the Android stuff (a very low bar as the Android apps pretty much don't work at all). Basically, I ran the Android apps all the way in one direction and then the IOS apps all the way back. I had much less "connectivity" and "activation" issues when running the IOS apps.
Use Electrify America App to activate chargers if the Porsche Apps don't work. This is by far the most reliable method of activating a charger. I often just used the EA app right off in order to skip all the frustration with the Porsche apps. After hours and hours on the road, I was happy to pay just to avoid the delays and headaches...
If all else fails, call Electrify America, explain your situation, and they will likely activate a free charge for you. However, It should be noted that calling Electrify America never activated a charger for me if the EA app itself could not. If I had to call EA, and I already tried the EA app, they could NEVER improve my situation (with a terminal reboot etc).
Keep the ABRP app handy. You might want to use it if you need to find a charger or re-route your trip. Do NOT rely on the Nav system as it makes some very questionable decisions.
Use PlugShare App to "Check In" with PlugShare whenever you arrive at your charging stops to let other users know what the condition of the station and chargers are. Pay it forward!
No longer agree. The onboard planners are much improved and will continue to do so.
Planning is everything! Plan before you go, know EXACTLY where you are going to stop, have multiple planning (ABRP, PlugShare) and activation (EA, Connect, Charging NA) solutions available on your phone! Do NOT rely on the Nav System to make intelligent routing or charging choices. Do NOT rely on the Porsche Apps (Connect and Charging NA) to be able to activate a charger.
No longer agree. Still need to know where your next stop is, but on main highways for the most part, finding charging stations is now very much like finding gas stations. On secondary roads is where we still need to plan in advance with a BEV.
The next 6 years (with solid state batteries maybe) and an infrastructure that will continue to improve is something I’m looking forward to…
anonymouse
Oxfordshire UK
You have many special challenges in the US, but it's good to hear that the infrastructure is improving.
In most of Europe (especially Germany, Norway, France, Benelux, and increasingly Spain) charging is pretty much "solved". I never need to look at the guess-o-meter when I take a road trip. There are 350+ kW chargers on most major routes and scattered around towns, sometimes even a dozen or more sites in a town. With the J1.2 Taycan's super fast charging speed a short break in driving equals 20-80% recharge and I'm off and moving in 15 mins.
In the UK our infrastructure is still patchy, although not as bad as the US. We have issues getting sufficient power to sites so lots are 150kW max; there are too many 50kW or 2-stall sites with insufficient government investment to improve; and one company grabbed all the motorway service area licenses and failed to invest in new tech which set us back several years. And too many selfish drivers (Porsche drives included) who have a long lunch while they block a charger to 100%. It's getting better and better, but not yet anywhere as good as on the Continent.
Mizzle51
Vancouver, WA US
2024 Porsche Taycan 4 CT
My main long drive use case is ~175 miles up I-5 between Seattle and Portland for a commute. I do this twice a month.
After doing it for 6 months, I'm pretty much not worried ever about charging. I charge my Gen1 up to 90% (CT + Offroad pack penalty is real and total range is 215 at best) via AC at both ends and I'm set. If its cold out, have several charging options which also have Tesla stations within walking / crawl on low SoC distance if things go completely sideways with EVGO or EA.
My partner doesn't really care about the ~5 min charging stops as unlike a gas car, you can keep the air and radio running while charging. Have yet to have any real charging failures, just the occasional de-rated charger but that's just a few more mins.
