Cold Climate Question
Lefty8235
NY
Taycan Turbo S, BMW M8GC, RSQ8, RS e-tron GT
Hey all. Have the TTS but it is not my daily anymore. Got it last winter and I work from home so not a ton of use then anyway but this year it’s mostly away for the winter.
That said, how often should I take it out in the winter just to give the battery a wake up, etc? I’m trying to at least get it going once per week but curious thoughts.
thanks.
thanks.
You could run the preheat when cold to use some juice for an hour and repeat. On alternate days you could then add some charge.
If laying up then consult the owners guide on how best to store.
JimBob
Toronto Canada
You don't need a wakeup. Just set the charge to 80% and plug it in every night. If leaving for an extended period, then refer to the attachment above.
sveinaan
Svein
Norway
21 Taycan 4s
I dont understand Your question. This is a car made for driving in same climate as every other car. I do not drive my Taycan often. But I drive it when needed. As I did with my 911 before I sold it. Summer and winter. You just need winter tires when its could.
