Electrical system fault/error
McgR
Taycan CT 4
hi im currenntly facing the same issue my car shows electical error system and wont go into drive or reverse mode .. please what did porsche say was the issue or how was it fixed you response would really help thanks.
In my car the on board charger needed to be replaced
adacci7
zeez
uae
porsche bentley aston martin
Hi Thanks for the quick response.. do you have the part number for the internal /onboard charging unit.
McgR
Taycan CT 4
No everything was done under guarantee. Took 3 weeks. Mostly waiting for the spare part I think.
adacci7
zeez
uae
Hopefully that fixes it for you mine has been replaced at least two times.
Hi, @Caraholic since you have similar experience @McgR has also shared is taycan wasnt going into drive or reverse did u have this also happened to your car and after changing the onboard charger where you. able to get a part number for it. im trying to narrow down my options of buying unwanted parts.
Caraholic
Don
South Carolina
Mine was always operating. I just had the battery error and the car would constantly fail to charge on level 2 or 3 if it’s hot out. Also would only top out at 150kw for a few seconds then stay around 100 at 350 stations. Biggest problem is getting in the car in the morning expecting 80% and being stuck with 30 as it failed overnight.
Vim Schrotnock
Vim
Cincinnati
Whenever you get an error message on your dash TAKE A PICTURE! I've done this a number of times, and taken the car into my dealer, who is excellent, and they have not been able to reproduce the error. They also did not see any error codes on the OBD. If I hadn't taken the picture, there would not have been any repairs. If you're getting an error message, this indicates that something is wrong with your car - Period. Taking a pic will show the dealer this is the case, and if they're good, they'll dig deeper and figure out what the problem is. I would NOT be comfortable 'rebooting' the car and figuring that everything is OK if the error is gone...:confused:
rdb29
2021 Taycan 4S
My 2021 4S has the 19.2 kW AC On-board Charger option.
3/2022: Failure to charge at home, car could be driven. HV charger replaced.
7/2024: Charge abruptly stopped overnight. “Electrical system error”. Car would not shift into gear and had to be towed for service. HV charge replaced. “Internal failure of the HV Charger control unit is not due to outside influence”
Today: Unplugged cable, got into car, another “Electrical system error”. Wouldn’t shift into gear. Powered off & locked the car, came back after 15min and fortunately could drive.
I simply could not recommend anyone buy a used gen 1 Taycan due to a fear of being stranded over a dumb failure like this that should still permit the car to move.
It’s painful because I love the car so much, the onboard charger is just been a total mess for me
This is on top of taking the car into my previous and current dealer three times to try and get Plug and Charge functioning. The first and most recent time, the problem wasn’t actually fixed. The second time, the surface advisor had no idea what the feature was and therefore it didn’t get written up properly for the service tech.
adacci7
zeez
uae
Hi how are you I have same issue please what did porsche say was the problem and what needs to be changed thanks hope to hear from you .
