Enviroguy
- Russ
- Mar 30, 2022
- Southeast Pennsylvania
- 2022 Porsche Taycan (base)
- #1
I had an unpleasant experience last week when I hit a pothole in the dark on a back road and blew out the front left tire. I was aware there was no spare, and spent a half hour trying to figure out how to inflate the tire using the provided "goo" and the dollar-store compressor provided with my 2022 base Taycan. No way, no how. Pulling the valve stem is no easy task, and then you can imagine having to put it back in with the goo oozing out of the tire. It wasn't going to work, especially in the dark, I had to have the car towed to the dealer (nearly an hour away), which took until the next day. I then discovered the dealer doesn't stock any tires! None! They had to order from a distributor, who apparently also didn't have them in stock, so three days in all were shot. So, my advice to anyone who ends up with a flat, is carry a can of fix-a-flat! It doesn't void the tire/wheel warranty I had purchased (thankfully) and will save a lot of time and effort compared to having the car towed. Even if you use the provided joke of a fix, unless you can get the tire up to 30 psi you can't drive it at highway speed anyway. At least if I'd had some fix-a-flat with me I could have limped up to the dealer, left it, and gotten a loaner for the time it took to do the replacement. Seriously, a $100,000 car ought to have a better option than is offered.
