Got rear ended with a bike rack
Flying ace
SF CA
GTS ST, 997.1 GT3, 991.1 GT3
Got my car back, and here is the part # for the bracket:
9J0803255B
@Flying ace @bomb721 @bsclywilly
Thanks, it's just the bracket that's unique?
I googled it and it yielded additional associated parts
Porsche Taycan 9J1 Bicycle carrier rack:
9J0827701B
9J0971124B
9J0803255B
This site has the most detailed pics of the parts together
https://rrr.lt/en/used-part/mam51088-9j0827701b-porsche-taycan-9j1-bicycle-carrier-rack
Here is the diagram, it appears to bolt into the crash beam. The harness will not work, not sure how important and whether parking sensors can be overwritten by driver when reversing. @bsclywilly you sold your bars with and without a harness plug, is the harness likely necessary?
https://www.boutiqueporschepoitiers.fr/pieces/taycan/9J1/2020/002-000/?focus=1
mikezhang31
I do not know if it is just the bracket that is unique. Someone would probably need to take off the rear diffuser to check if there are prexisting bolt holes in non CT variants.
Flying ace
SF CA
Did they replace the crash bar?
mikezhang31
it would seem that they did.
Porsche Taycan Got rear ended with a bike rack 1738587425735-8g
Flying ace
SF CA
@mikezhang31 did they also replace the black trim part of the rear bumper (where the red reflector and the pop out piece is) ?
What about the undertray diffuser under the black trim of If please lmk the part numbers.
mikezhang31
This is all the parts replaced or repaired that was classified as rear bumper:
Porsche Taycan Got rear ended with a bike rack 1741780313473-7k
Flying ace
SF CA
Yep, the lower cover was replaced, thank you!
