How to remove a-pillar?
TaycanCook
NYC
MG 4S CT
I haven't been able to find any pictures, so I'm asking. Do you have pictures of what the a pillar looks like underneath so I know how to remove it? I want to fix how the dealer installed it, but I also don't want to break any clips. Going back to the dealer is always a process which I want to avoid.
Dee
Dee
A lot
Cut top and bottom and you can remove the a-pillar.
We're here to help you. ??
Moonstone
Scotland
Taycan GTS, R8 V10+, Q5 Edition 1
I get that you asked this question months ago but saw this on the "similar threads" box at the bottom of the page.
The answer to your question is to loosen it out with nothing but a bit of force and then you'll see a metal clip at the top that has a sliding flat-section that you need to slide out with a hook in order to release the clip. it has a hole in it.
The trim is then secured by a strap attached to a push fitting that you need to remove in order to fully uninstall the A-Pillar trim piece.
tchavei
Portugal
Very interesting but I feel that might be problematic to put back?
I'm definitely not from the YouTube generation but in this case, pics or videos would be helpful ?
Moonstone
Scotland
It wasn’t for me but if you’re not capable of figuring this out in-situ I really don’t recommend you mess around with it.
I’ve no need to remove mine again and didn’t take any photos or anything as it’s fairly simple to be honest.
tchavei
Portugal
If it's simple, I believe you.
TaycanCook
TaycanCook
NYC
MG 4S CT
Go on ebay and search for taycan a pillar. You will find a few listings with pics detailed enough that you might want to attempt this. There looks to be two clips, top and middle. The rest is friction fit from what it looks like.
