Is my driveway too steep for 23 GTS?
tophamn
Neil
Bristol UK
Taycan ST GTS
Hello hive. I’m looking at buying
a MY23 GTS but am concerned about my driveway angle of 15 degrees. The car has the adjustable height feature but I can’t find approach angles with it on the highest setting. Thanks.
As others have said: it's not the slope angle you need to worry about but sharp changes which lead to grounding, either front, rear or middle, depending on how the slope changes and how quickly.
I have a 23 GTS ST and my drive slopes but it's the hump between the drive and the road which sometimes grounds out - I have to raise the car and move out very slowly to prevent the car touching as it bumps over the (tiny!) kerb.
I think if you're at all worried then it won't work: it's a LOW car (even when raised) with a long wheelbase.
ct4s
Bob
ST 4S
Get a CT. From memory it can go 3.5cm higher than a ST.
bluegrassvroom
Neil
Kentucky, USA
2021 taycan 4s
i had to bust out the lower part of my driveway where it hit the street and do a more gradual slope - but it was just 1-2 feet i re-did. My driveway hitting the street was more of a standard curb (weirdest thing ever) than a driveway to road connection. my driveway was STEEP as well, but it was just the harsh angle at the very beginning that caused it to scrape
Daiwee
Audi R8, Land Rover Discovery 4, Hymer Van S.
noted.
yes I was already checking that option out today. I’m optimistic that it won’t be necssry though based on some measurements I’ve taken …
Daiwee
Thanks for the input. Appreciate it.
Flying ace
SF CA
GTS ST, 997.1 GT3, 991.1 GT3
In my neighborhood several people use a heavy rubber device from https://www.bridjit.com/ to give low clearance cars a chance to skip over curbs and get up on the driveway without scraping.
Works really well.
I use something like this for my 997 GT3 which has no FAL. I don't configure it this way though, more at 45 degrees across the edge, looks odd, but it works.
I store it inside because the 997 is rarely used. But it would be inconvenient if it has to be outside perpetually, bc I have street cleaning, and gene generally high foot traffic on my sidewalk
