More charge than available capacity?
jonjon808
4S Cross Turismo
I'm sure I am not the first on this, but my 2023 4SCT ran down to 0% charge today on the way in to work (sort of by design, but did get a little squeaky towards the end). It took 4hr 15m at 20kW to get to 100%, but the charger says that it squeezed in 87.6kWh in that time, so almost 4kWh more than the literature says is the available capacity. I guess this will be down to losses between the charger and the battery, but 5% loss seems pretty significant
RacingDuck
Bernhard
Germany
Hyundai Ioniq 5, Honda Civic Type R
5 % losses is pretty good.
On DC chargers I'm seeing like 10 % (difference between BC consumption and calculated consumption)
But of course the AC is working hard to maintain temperature there.
Boss Hogg
J2 ST Turbo, 981 GT4
losses and cooling
faster charging = more heat and more cooling power needed
bn8959
Ben
UK, South West
Taycan GTS ST (MY24)
If you charged on a measly 1.2kW, your losses would be around 40%! There is around 700W base use before you even start putting anything in to the battery. As the charge rate goes up, you'll also get more used on cooling etc. 4kWh over a full charge seems as about a lower loss as you could get - maybe slightly less charging at 7.2kW.
gtm
George
Jacksonville, FL
Your usable capacity new was 86.7 kWh. See: https://www.taycanforum.com/forum/threads/?-baseline-for-hv-battery-soh-performance-battery-degradation-data-by-taycan-owners.12815/ Third paragraph of the first post. Your battery has degraded to some extent. Assuming a SoH of 92% on a 2023 battery gives you a usable capacity of about 80 kWh now. So right around a 10% loss for your charging session.
