Noise from trunk (hooks opened but not fixed all)
miglio
Italy
Taycan 4s - Cayenne Coupe Hybrid - Carrera S 992
Hello everybody, in my Taycan gts sport turismo there is an annoying noise coming from the trunk. initially I solved by opening the hooks that are present internally on the sides of the trunk ... the noise has improved but not canceled. has anyone noticed? has anyone tried to fix with a tape / felt?
I think that the internal trunk coverage divided in the two parts doesn’t help this issue…
Thank you
Jayyvr890
Canada
It has been reported a common source of rattling in the hatchbacks is fro the rear cargo cover. Make sure the support tabs are unfolded.
miglio
miglio
Italy
Support tab are all 4 opened… I’ve check if there are others (as I read in some past threads) but mine here in Italy has no more than 2 tabs …
am I distract or is possibile that mine GTS ST have no more than 2 ?
seems to be not enough to block well the cargo coverage
ciaranob
Yes I had posted a 'cure' if you will for the tray rattle some time ago now (see post here #1 ) - it is also really important on the CT to ensure that you 'seat' the cover tray very firmly into its receiving slots before resting on the open hooks which are designed to be supports for the tray.
Obviously you can test with the tray fully removed (I'm sure you have) to check first that the noise is not coming from somewhere else. If the noise(s) only occurs with tray installed then you simply need to find a way to anchor it better yourself (as you suggest) or if it really is annoying have the dealership check it and maybe even swap it out?
Curious to hear your solution.
