Option choices compromises
Jeremy
St. Louis, MO
Is the US the same as the UK, in that the 22kW option requires 3-phase for any benefit? Reading other posts, i presume not - due to the crazy way the US 240v feeds work?
I believe I am correct in saying single phase is max 7.4kW (with or without the 22kW option). If you have 3-phase then its 11kW without the option and 22kW with.
Ill add that to post 1 if so - just want to confirm if its different for the US.
NA AC chargers are single phase, maxing out at 19.2kW using 80A at 240VAC.
bsclywilly
San Jose
CT4
A couple other option compromises:
  • 18-way seats doesn’t allow massage option
  • If ACC isn’t spec’d then ALK and Innodrive can’t be added later via FOD.
bn8959
bn8959
Ben
UK, South West
Taycan GTS ST (MY24)
Thanks. Got the Innodrive FOD limitation in there. Ive added the 18-way compromise for completeness, although the configurator wont let you select that combo anyway. Im especially trying to find out all those gotchas that arent obvious. eg the 'reduction in storage space' on the Bose and Burmester, I cant find any pictures with and without this - Porsche should show the difference for clarity. Also on the Innodrive FOD, it says its not feature comparible to Innodrive out of the factory - but dosent actually say what the differences are (eg it mentions additional collision warning on the option description - do you not get these via FOD?).
Cheers.
Cherryjock
Scotland
Taycan Cross Turismo 4
Thanks. Would be interesting to know - exactly the information I want to know, but cant find out easily - what exactly are the differences and compromised between base, Bose and Burmester - hence this thread :p
Maybe some photos of the under floor storage area for each option would be good. Ultimately I didnt care, as I wanted Burmester anyway :)
This is the increased (oddly shaped) space the UK standard stereo leaves. The shaped foam is for the portable charger. For that reason you do not get the fabric cable bag (to keep the portable charger in) with the standard stereo.
I had the Bose surround in a loaner for 1 month before I got my car and I did not regret my choice when mine arrived
Porsche Taycan Option choices compromises 20230917_175648
Porsche Taycan Option choices compromises 20230917_175712
. It is not worth an extra £1052 to me.
bn8959
bn8959
Ben
UK, South West
Very useful info! Finally the difference is clear :)
Thank you.
bn8959
bn8959
Ben
UK, South West
I presume the overall height of the boot floor remains the same either way? It’s just extra space gained in the lower storage cubby hole?
Cherryjock
Scotland
Cheers.
With FOD ALK I don't get the green lines on either side of the distance selection that, I think, represent the car 'seeing' one or both lane markers.
Porsche Taycan Option choices compromises 20230917_180012
Cherryjock
Scotland
I think so, the difference is no sub woofer.
B61
Bine
SI
Can't recall where I read it, it might not apply to the Taycan- the additional rear airbags could seriously or fatally injure dogs on the rear seat.
How comes?
I mean, why would harm a dog, but save a child?
B61
Bine
SI
AFAIK, with Bose the size of the trunk is smaller because of subwoofer.
Don’t know for Burmester.
WuffvonTrips
Paul
Up North
Taycan Turbo CT
How comes?
I think it's the risk that the explosive inflation of side airbags in the rear could forcefully impact any anyone- animal, child or even adult- if they aren't in the proper place, i.e. sitting upright wearing a seatbelt, or in an approved child seat. Certainly any body lying across the rear seats is at risk.
McgR
Taycan CT 4
You did switch it on I presume ?
