PCCB squeal
reggie-g75
Richard
Stourbridge
2021 Taycan Turbo S, 992 C4S, 2020 Panamera GTS ST
Hi, have a Taycan Turbo S with really noisy brakes. Only make a squeal/honk in damp and wet weather when the car finally comes to a halt. Not seen much chatter about it - is it normal for PCCBs or do I have an issue? TIA
Sidicks
Kent
Never had the squealing problem when I had PCCBs, but have heard it mentioned By others. The advice then was a sequence of very hard braking to ‘clean’ the discs. Not sure if that is feasible for an electric car.
SergeyIndy
Sergey
Indianapolis
Not normal on PCCBs so hopefully you are under warranty and can check them out asap or any repair replace will be very expensive.
Expected on PSCBs on Macan/Cayenne models and I just had them replaced on a Cayenne under a TSB that came out in the fall of 2021 after everyone is experiencing the squealing as soon as 100 miles. Cost to Porsche from my dealer $6,480 USD.
