Pre-conditioning battery for charge
Novemberwhisky
Nicholas
BCN
GTS ST Crayon.
So if the porsche Nav System knows you’re routing to a charger, the battery will pre-condition to enable the fastest rate of charging. If my chosen charging point is not in the Porsche database, can i manually set the battery to pre-condition?
what rate of charge requires pre-conditioning >50KW, >100KW?
Porsche-Guru
BMW M4, BMW 535, Taycan 4S - gone, in a 911now
I don’t think there is a manual way to ‘precondition’ for battery charging - but I would like to know if anything exists.
The alternative maybe to set car to Sport+ mode (some miles before your charge stop) and drive hard - this will get the the battery heated up !
Genau
Reston, Virginia
In one of the prior threads on this topic, @WindsurfUS1111 reports that you can use a voice command to pre-heat the battery:
Novemberwhisky
Novemberwhisky
Nicholas
BCN
GTS ST Crayon.
