Recuperation issue?
007
Poland
Taycan Turbo S
I’ve noticed that in the snow with slippage, I get the message that the recuperation is unavailable.
WuffvonTrips
Paul
Up North
Taycan Turbo CT
Interesting. Maybe it's deactivated when the car recognises that there's not enough grip to drive the regen without the wheels slipping?
ExTesla Driver
Naveed
Worcestershire
Porsche TAYCAN 4S
I am Ex Tesla Model S and New Taycan 4S driver. My recuperation screen in the centre of the car worked a couple of times. Now it only shows Green fixed image, Battery level seems to change. Just wonder if its a known software issue or the recuperation is not working?
Hirschaj
Jim
Austin TX
Share a photo?
Freeewilly
William
Orange County, CA
2022 Taycan, 2025 Taycan
Hi, new Taycan owner. When I apply physical brake, my power meter shows absolutely no recuperation in the grey ring of the power meter. Is not normal?
Overrun recuperation works, I see green bar in the power meter.
Outside temperature `75 degrees, battery about 40%.
SergeyIndy
Sergey
Indianapolis
This is normal when the car has not been driven for a while to let the car use physical brakes, to clean them, etc. This typically happens during first 10 minutes a few miles with a physical brakes engaging a few times. Then, normal regen when pressing on the brake pedal with green regen bar appearing should be seen, unless you are at low single digit speeds when only physical brakes are used.
