Regen - wont turn off!
VONRichie
Uk
Taycan RWD
i have the dash button set to turn regen on and off - today its on and it will not turn off either through the pcm or using the quick set button?
any ideas?
Rich
any ideas?
Rich
Did you try the button on the steering wheel specifically for regen - auto, off, on (no need to go near the PCM)?
VONRichie
VONRichie
Uk
Taycan RWD
yes mate "using the quick set button?" was in my orig post
Ok so random thought time (has worked on other issues). Lock the car with your primary key. Unlock it with your secondary key (and secondary Porsche ID) - this may reset it. Repeat back to your primary key.
Failing that it may just clear overnight or after a few short hours when the car has gone to sleep.
Henke
MY25 has replaced the regen button with a music forward button.
VONRichie
VONRichie
Uk
Taycan RWD
yes sorry 25 jii - but i have the dash button set to turn it on and off, but it wont and neither will it through the pcm - i have videoed the issue waiting for a call back from the dealer - 5 days of ownership - 2nd issue! great
VONRichie
VONRichie
Uk
Taycan RWD
Update, factory reset cleared the issue for a day, now waiting to have a new pcm fitted.
Midlifecrisis
Worcestershire
I had an issue with an MY25 courtesy car and discovered the regen button on the steering wheel had changed to something else. It seemed that regen was on all of the time. I gave up messing with it as I only had the car for a day, but the defaults seemed different to my MY23
RBGtaycan
Bob
Long Island, New York
alternatively an engineering reset of the PCM: two finger swipe....?
VONRichie
VONRichie
Uk
Taycan RWD
New PCM? What happened?
The regen will only switch between auto and on, it will not turn off.
Dealer is going to replace the pcm as they can not find a reason for it.
