- Adrian
- Jan 11, 2021
- Aberdeen, Scotland
- 992.2, ex GTS ST & 4S owner, Macan T
I don't use PLC - can be problematic and historically can lead to unintended 12v battery drain - DISABLE PLC. Note that the PLC aspect of concern is the PLC connection from the PMCC to the car (not PLC to your router / PMCC).HI W1NGE
in your experience is it better to use wifi set up or PLC - if I use wifi I cannot use the PLC setting as it asks me to switch off/deactivate - ?
I have reset and obviously trialling which works best and my initial observation although wifi connected ok is it better just to leave it by using settings under car control as I have been using WIFI but this maybe where my issue is (trust this makes sense)
vbr
Ron
Use WiFi (or PMCC hotspot) but in reality you rarely need to connect to the PMCC once it has been setup (and besides all setup can be performed via the touch panel). PMCC will need to be registered with your Porsche ID and logically therefore will need a clear path to the internet for this step and subsequent data uploads (and updates).
All charging control is via My Porsche App or the charging functions in the PCM.
These are my settings:
