RWD coil suspension height vs RWD air suspension Lift hight.
hmmwv79
Jason
San Jose, CA, USA
Taycan base RWD
RWD coil suspension height vs RWD air suspension Lift high.
Which height is higher? My wife she hate front lips getting scratch...
jasperp
jasper
Flanders
tesla,porsche
I don't know the actual numbers but I can tell you that in practice the RWD default height is fine. I drive in a region with many speed bumps, and so far, I did not touch the road with the front or rear of the car.
GTS ST, Macan T
Both will have the same ride height will they not when air is set to normal? Lifting is therefore higher - 20mm (can't remember exactly).
XLR82XS
LXA
SW FL | Vegas
Air suspension in highest setting is higher. Tell you wife with smart lift she can avoid front lip scrapes.
hmmwv79
Jason
San Jose, CA, USA
Taycan base RWD
Oh really? Do we have a document to check? I think I need to add this air suspension for this order. Thank you!
4thPcar
Del Mar CA
with air suspension you can lift the car as you approach high inclines. The car will ask you if you wish to remember this setting so that it will lift each time. For example, I have the car lift as I approach my driveway. It works quite well. You can also have as default a normal, lowered, or low setting for normal driving.
and if you plan to option air suspension you should absolutely add rear axle steering, which requires this feature.
hmmwv79
Jason
San Jose, CA, USA
Taycan base RWD
I can only choose Air suspension without rear axle steering.
4thPcar
Del Mar CA
You are misunderstanding my point. Get both. You won't be disappointed. Research other threads that speak to the advantages.
gusone
gus
South East London
BMW Series 3 XDRIVE M SPORT
I live in South East London. We have millions of speed bumps of all kinds such as the full road hump, the dual square ones. The RWD coils clear them at speed. In fact because the car is so wide you can hammer over the dual squares bumps if you line up correctly and they go straight under the car not touching the wheels. The ride is comfy so I just don't see the need for any kind of lift unless a steep drive or something where it is critical.
4thPcar
Del Mar CA
I was not necessarily interested in air suspension but what I was after was RAS and air suspension was a "pre-requisite." So I bought both. I'll never know what the ride would be like without it, but I have argued elsewhere (see my thread on "First 1000 miles") that the RAS is the most valuable option on the car. Its a game changer for other reasons, such as being able to turn this large car in very tight corners. I am SOOOO glad I got it, and I can absolutely tell the difference because there is no way I could turn the car without making a 3-point turn but for this option.
