Gkwan
- Stéphane
- Nov 28, 2025
- France
- Taycan Turbo (June 2020)
- #1
Hi guys,
My MY20 Turbo Mission E w/RWS has beautiful looks but after a lot of reading here, I'm starting to wonder if I should switch to a MY25 or 26 with different model/spec to improve the points I don't like (everything else is great).
Rear wheel steering : this post describes exactly what I've been feeling
https://www.taycanforum.com/forum/threads/taycan-rws-issues.27406/
A sort of slight wobbling/instability from the rear that doesn't happen in all conditions.
For my neophyte needs, the advantage I see to RWS is better maneuverability in town. I'm not doing track, or insane speeds on small roads (but I do like driving in a "spirited" way sometimes, obviously). So if this slight unstability is unavoidable then I won't spec it in my next J1.2
Range : that's "fixed" with J1.2 Perf+ battery, should get ~630km WLTP ie 350km in Range at 130km/h on the highway (maybe 400, both being fine for me).
Need best possible Comfort :
@prj 's advice helped a lot : best comfort level is " Cross Turismo MY25 or later + 20'' tires + Active Ride ".
However I want to keep the looks of a Sedan (otherwise I'd switch to the new Cayenne
), so the conclusion is "anything except the GTS and Turbo GT" J1.2 with 20" and PAR.
Seats : I have the 18 positions heated/ventilated, I'll probably go for the 14 positions as I read many people saying it's more comfortable (I'm not large but with Active Ride I should feel less side-to-side movement, so no need anymore to be in a "tightened" lateral seat position I think ?)
I'll keep heated, ventilated and will add massage if it's worth it (didn't try).
Other options : I'll take all the "multimedia" ones, all driving aids, parking aids, etc, more on the "max" end of the spectrum.
Problem is there are so many Taycan sedan models, it's difficult to choose which one to configure :
@prj you said
I'll try both I guess
Regarding the "tuned module", is it https://www.mapev.net/taycan-turbo/ ?
I see guys in Paris (BR-Performance), I suppose I can check with them.
I don't necessarily need the 680hp of my Turbo, but it's possible to activate it a few times now & then to have a bit of fun that's a great option
@prj you said
So I'm hesitating between starting with a "4 black" & add stuff (can't see the difference with "4S black" despite Porsche's comparrison tool!!), or even the basic Taycan & add stuff because apparently the black edition is only offered with 21" wheels, while I'll try to stick to 20".Black edition 4S is the best bang for the buck. If power is a problem get our tuned module and you have 940 PS
