Target charge was automatically set to 255%
McgR
Taycan CT 4
Did you get to the bottom of this issue, @Kippax? - I got this exact issue over the weekend and I now can't charge beyond about 23%. I did use route guidance to get me home Saturday and the nav wanted to send me to a charger, even though I was only a mile from home - so obviously I ignored it. I've cancelled navigation, there are no charging profiles or timers set. I also saw "Charging Planer" was active in the nav settings so I un-ticked it but I still have the "Target charge was automatically set to 255%" message. Any help appreciated.
You can solve this by entering a new far destination and let pcm calculate the route and charge stops and cancel it again. Charge planner will only be canceled like this. Had the same. Two finger reset didn’t work. Other resets didn’t work either.
usually what you did works but sometimes it doesn’t. And you need the second work around. Stupid bug.
tophamn
Neil
Bristol UK
Taycan ST GTS (gone); Taycan Turbo-S ST
Thanks for this, @McgR, this fixed it for me :) - I got a full charge this morning. It's certainly a stupid bug but easy to work round - when you know how!
McgR
Taycan CT 4
I know. Had this at a stop over for a night in Germany last year. Glad I could help. the work around is easy but if you don’t know it really annoying because you are blocked with a low soc.
