JimBob
- James
- Jan 26, 2021
- Toronto Canada
- Taycan 4S
- #16
Can you see if you can locate that article? It sounds logically inconsistent. To recommend Range mode for long distance trips and then recommend a reduced battery charge which yields lower range sounds strange.
Not really planning on a test in Normal mode. Had thought about it, but the combinations and permutations become endless.
Next one will be when the outside temperature gets to 0C/32F. Basically creep up in 10 degree increments until summer maximums. I am curious as to what the distance curve looks like with changes in temperature with as many factors held constant as possible.
