Things lost after update
Mtljckt
Bucharest
Taycan 4S CT, BMW i3s, X5, 540i
I'm happy I got the Android on my 2021 4S, some extra mileage (and some bad looking colorful icons) but the car is now missing a few things.
Perhaps you can help with a fix or add the options you missed.
- The automatic lift locations are still stored but the car doesn't raise anymore at these locations, despite the option being ON.
- Right side mirror goes down in Reverse but will not comeback once I go back in Drive. I need to manually switch on the left mirror for the rear one to go up again.
B61
Bine
SI
Sorry to hear, but i don’t have those problems.
The automatic lift problem has been mentioned on here before. Try a search on the forum.
Your mirror issue may be delayed so that you need to drive forward, not just engage drive mode. I have seen similar behaviour, but once I start to drive it goes back to its setting?
B61
Bine
SI
Thst’s correct.
You have to start drive forward and mirror will move back on its original ,position.
offplan
UAE
Taycan 4S , bicycle , my own feet
1- Ionizer icon when activated. Now I’m not sure if the ionizer even works
2- apple CarPlay automatically comes on when using the radio after a few minutes even though I switched out of carplay
SmartLift - I had this issue as have others. Locations saved but the lift doesn't function. Problem self-cleared after 2 weeks. I also deleted also saved locations and re-added but this didn't work until after 2 weeks so I'd wait before deleting.
Mirror - there is a delay (even when stationary) which is normal operation. The mirror will stay dipped for some seconds before returning to normal. If you drive off the mirror will reset as normal. Same across all Porsches for some years.
bootsie
Steve
Northants, UK
Taycan Turbo, Golf GTI 16v
Mine did this pre-update. Annoyed the hell out of me for some reason!
Jayyvr890
Canada
Lol I lost the ability to display map view in the instrument cluster. Multiple reboots with no change.
H@wk
H
Norway
Porsche Taycan 4S+, Ford Ranger 2.2
Anyone know why Porsche removed the «All Wheel» axle information from the leftmost display? I briefly tried searching for it to no avail.
It has been removed.
Animated trip display showing drive and recuperation in the central display.
Vehicle - Trip display.
