- David
- Jan 28, 2019
- Santa Cruz
charger doesn’t matter -all the same - it’s circuit capacity that matters - amps/breaker size - for the same breaker size every charger is the same speed - install a circuit with xx breaker size - then buy the charger that matches the breaker/circuit size you have installedThanks for all the replies. Narrowed it down to the Tesla or wall or plug-in ,
Any idea how much time does the wall box plug-in take to charge the car full.
standard taycan maxes out at 48 amps or a 60 amp breaker
optional vehicle onboard charger can bump that to 80 amp charge rate or 100 amp breaker (100 amp dedicated circuit for your garage to charger you EV is possible but most likely very very expensive).
see this post for a break down of charging speeds base on types of EVSE equipment and breaker size installed.
EV chargers (called EVSE's) are not faster/slower than one another - they are all the same speed for the same size breaker/circuit if the EVSE purchased matches the breaker/circuit size you install.
https://www.taycanforum.com/forum/t...-it-take-to-charge-my-taycan-from-blah.12279/
