What is this Porsche bag?
RED!
RED!
Stu
Toronto
'24 ST GTS, 996 GT2, 87 Turbo Cup car, 04 NSX
The OEM should be fine if put on the correct way round. Some folk put the bars on back to front which led to damage on the rails.
Interesting, cuts the fear a bit!
I can find gently used Aeroblades for 40-50% less than the dealers' willingness to give me 15% off OEMs, is there a reason to buy OEM over Thule? (I've read the comments in the forum, but I'm still not sure which way to go)
No real reason and I suspect Thule make both. Personally, I've always chosen Thule for my Porsches apart from one (original Cayenne S many moons ago).
There is a thread which discusses issues with the cross bars and mistakes made when fitting which led to damage.
Flying ace
SF CA
GTS ST, 997.1 GT3, 991.1 GT3
I was able to see aero blades on a Taycan CT and it looks very well designed and fitment was great. IMO aeroblades advantage is the lower profile design.
I've mounted and dismounted my OEM bars probably 10 times by now, and I have it rehearsed such that I'm confident on not scratching the bars. I also use painters tape to ensure that.
OEM fitment is tight and perfect. The only downside is the end covers do not fit perfectly unless you apply pressure to the cover when you lock it in. Otherwise there will be a small seam.
Porsche Taycan What is this Porsche bag? PXL_20251223_215528898
Porsche Taycan What is this Porsche bag? PXL_20250928_183116315
RED!
RED!
Stu
Toronto
Curious about your drop in mileage
Do you have a sense of the loss from:
1) just the bars
2) bars and roof box
On 100% charge, in winter, the guessometer is estimating that I will arrive at 27%. My gutometer is telling me that a roof box in winter will need a charging stop for safe arrival.
1) just the bars
Clearly the bars will contribute and then add a box on top ain't going to help with range.
There is an aero box but...
Flying ace
SF CA
1) just the bars
The ski rack is about a 0.2 mi/kwh impact. I've only driven the same winter route once without the rack and yielded 2.6 mi/kwh vs 2.4 mi/kwh.
I don't have a measurement for the box impact. My records show that I was able to achieve a round trip average of 2.8 mi/kwh with a box, so likely minimal impact.
RED!
RED!
Stu
Toronto
This is awesome data! Thanks!
