2025 Taycan 4s Cross Turismo Range
Phil Prosapio
Phil
Little Falls,MN
Taycan 4S CT 2025, 9114GTS’ 2012 6 speed
Is anyone else seeing range like this? I know it’s nice and warm out but, this is a good 70-80 miles more than the first few months after delivery. Currently, on a long trip.
In a previous post, I mentioned I did a technique where you drain the battery down to one percent, leave it for six hours, plug it in to plug it into 100%and leave it for six hours before driving . It’s been consistently many miles of range better, which is at least a 20% improvement.
Porsche Taycan 2025 Taycan 4s Cross Turismo Range IMG_4794
69Mach390
Florida
24 Taycan 4S
This just means you drive slow.
Drive faster!!! It’s a Porsche, it wants to go!
Displayed range is similar to displayed range on a gas car- it changes based on your driving patterns and is only an estimate.
Phil Prosapio
Phil Prosapio
Phil
Little Falls,MN
This is after driving 75plus miles an hour on Highways from Central Minnesota to Madison Wisconsin and the range was pretty consistent. Noted that where we normally charge on this trip had much better range on arrival. Previously with my 2022 GTS we had to stop twice to charge!
69Mach390
Florida
24 Taycan 4S
Enjoy the warm weather and the J1.2 larger battery!
To answer your question though, no, your actual range didn’t increase 20% by rebalancing the battery. Displayed range is always just a guess. Actual range is determined by how you drive and weather outside. You can see a 10% swing just based on which way the wind blows and 30% or more on temperature.
Phil Prosapio
Phil Prosapio
Phil
Little Falls,MN
Yes, I know that but, it sure makes you feel better than when it’s 24 below and I used to have 160 miles range in the ‘22.
joowon213
Joowon
It's because you got the 19in wheels.
The 21 inch and 19 inch wheels show a noticeable difference in driving range especially on highway environment.
sarends
Steve
Bellvue, CO
2024 Mercedes EQE 500 SUV, 2023 Mercedes EQS 580, 1997 BMW M3
I just bought our 2025 Taycan 4S. We drove it 1,000 miles back to CO and our range at 80MPH was about 300 miles. However, since we've been back in Colorado the range has averaged 380 miles! I keep waiting for it to get worse and it just keeps getting incredible range.
Porsche Taycan 2025 Taycan 4s Cross Turismo Range keep IMG_8125
Phil Prosapio
Phil Prosapio
Phil
Little Falls,MN
That’s true. Here’s a question I have, I had a set of 21 inch wheels and winter tires from my previous Taycan that I was planning on putting on this winter. Besides the mileage decrease expected, does anyone know if that’s going to be a problem?
cityhpper
Johan
Agder
22 GTS ST, 22 CT4 (sold).
No problem mechanically, but you will have to replace the TPMS-sensors in each wheel if you want to monitor the tyre pressure (and avoid error messages).
Phil Prosapio
Phil Prosapio
Phil
Little Falls,MN
why is that? These tires read pressures off of the 22 GTS just fine. Just not sure why they won’t be recognized?
cityhpper
Johan
Agder
The TPMS in the J1.2 uses a different frequency than what was in the J1.1 (i.e. your 2022 model). So your car would not be able to communicate with the wheels from a 2022-model.
Swapping out the sensors in the wheels lets you combine a J1.1 wheel with a J1.2 car, and vice verca.
ct4s
Bob
ST 4S
Wow - that's high.
300 for me.J1.2, 21"
