AC Performs Poorly in Hot Weather
NewPdude
Rhett
Tempe AZ
BMW M440i
I hope to be able to provide some data into this conversation within a week assuming a truck is available to pick up my car from port. It’s really hot in Austin this weekend. ?
Congrats on the delivery!! If I remember correctly didn’t you have you Mamba green CT on the Felicity Ace? If so that’s rapid production… but I’m sure it wasn’t for you. Enjoy!!!
Hirschaj
Jim
Austin TX
Thanks, yes I did have a Mamba Green CT4 on Felicity Ace. The car I’m picking up soon is not the 2nd build of the Mamba Green car but instead a Chalk CT4 that was a dealer spec. I still don’t have a build date for the replacement of the Mamba that was lost at sea.
NewPdude
Rhett
Tempe AZ
BMW M440i
Still a worthy color!! Are you getting the “Mamba” as well? First rule of spending… why get just one when you can have two at twice the price!!
Hirschaj
Jim
Austin TX
Haha, I like the way you think. The plan right now is to sell the Chalk one when the Mamba finally arrives.
ciaranob
Congrats on being able to find and secure a temporary replacement - not easy these days - enjoy!
kwh estate
J
Richmond, VA
2022 cross turismo 4
hey everyone - my AC has never cooled properly since day 1 did not notice until a few weeks ago since I took delivery in Dec 2021, unfortunately there is a part that needs to be replaced in order for the system to cool my 2022 CT4 - I ll be garaging it soon as the temps rise and I ll be driving a rental for the summer until this part gets manufactured and delivered to US.
tutis
Zurich
Porsche
I am not sure, but I think I've noticed a difference in AC performance depending on which driving mode the car is in (Normal, Range, Sport) as well as the battery temperature. Just after a heavy DC fast charging the AC output in the car is meh, and I suspect it is because the AC is actively working to cool the battery. When in Range mode the AC is also a bit lazy. Obviously if you have the AC on ECO mode then you're further shooting yourself in the foot...
Finally, as with all cars AC is not magic; it relies on radiators to disperse the heat. So when you are sitting in traffic and there's very little airflow over the AC radiators then the car cannot dump the heat outside as easily... therefore the AC in the car doesn't fully perform.
TLDR; if you really want to see if you AC is working then drive in Normal mode with a battery that is at less than 30º celsius and at steady driving speeds of around 30mph. AC air blowing in the car when on Low setting should be ≤10º celsius.
rs38
Düsseldorf
Taycan,GT2,i8,Tesla
it should be at way below 10°C even if your car is standing still. That's why car's have fans blowing the radiators :)
Goldbros
Goldbros
CA
2021 Taycan RWD
Heard back from dealer and apparently it is the AC pressure sensors. Hope this takes care of it.
Car still in for front seatbelts recall and checking the battery as it stalled several months ago. No issues until a couple weeks ago when the feared message appeared again.
Hopefully these are not symptoms of a bigger problem cause the car is a blast to drive.
DerekS
DerekS
Derek
Los Gatos, CA
2025 Taycan GTS
Are you sure? The sensor issue was apparently fixed the first week of 2021 so in theory any car built after that date would be ok.
Goldbros
Goldbros
CA
2021 Taycan RWD
I picked my car from the lot inventory in July 21 so assume it went into production after the sensor issue was addressed.
Of course I’m not sure but I have to give them the benefit of the doubt. They have been really good to me (after some initial hiccups)…
Hirschaj
Jim
Austin TX
I picked up my CT4 yesterday in Louisville KY. It was a hot day with temps between 90-95 and high humidity. The A/C works great and has no problem at all keeping the vehicle cool. I do NOT have the insulated glass and I have a black interior.
DerekS
DerekS
Derek
Los Gatos, CA
2025 Taycan GTS
I might be an idiot. I've started changing from "diffused" to "focused" when it feels like it's not keeping up, and that seems to do the trick.
jvincent
SF Bay Area, CA USA
Ice Grey CT4
Noticed the same after a recent 400 mile trip in moderate heat. Got tired of being blown on and went to diffused. It was OK, but only if I bumped up the fan speed manually. Eco mode.
Goldbros
Goldbros
CA
2021 Taycan RWD
I got my car back. Was told it was the sensor and after replacement AC has been working for a few days.
They didn’t have supplies (tape or whatever the fix) for the front seatbelt recall yet
