Vision
NY/FL
Turbo S
You don't need any programming skills (you are not doing programming, just changing 4 numbers in a box!).
Computer - most people already have that.
I haven't checked the ID of the suspension controller but chances are you can use VCDS and OBD11 as well.
It takes just a minute to change the 4 adaptation values to lower or higher value, and that doesn't involve messing around under the car.
I just never see the point of doing something with hardware that can be done easily with software.
I tried VCDS (only seems to work on the e-tron). Also bought the obd11, no luck with that either.
nizmugen
San Diego, CA
2023 Taycan 4 Cross Turismo
Yeah, I could do that. The only thing is that it will work until MY23. From MY24 the cars have SFD2 and there is no way to unlock that without an official PIWIS account. So for newer cars the lowering links method is the way to go.
Add me as a customer if you'd be able to add that as a paid option.
